Audiovox CDM-8900 Antenna Replacement
  1. Audiovox CDM-8900 Antenna Replacement, Battery: step 1, image 1 of 2 Audiovox CDM-8900 Antenna Replacement, Battery: step 1, image 2 of 2
    • Hold the phone in one hand, slide the latch up, and pull the battery up to remove it.
  2. Audiovox CDM-8900 Antenna Replacement, Antenna: step 2, image 1 of 3 Audiovox CDM-8900 Antenna Replacement, Antenna: step 2, image 2 of 3 Audiovox CDM-8900 Antenna Replacement, Antenna: step 2, image 3 of 3
    • Grasp the antenna at its base and twist to unscrew.
    • Remove the antenna along with its plastic casing from inside the battery housing. Keep the antenna in the plastic casing for reassembly.
3 other people completed this guide.
Aaron Shaw
159 Reputation
6 Guides authored
Cal Poly, Team 28-31, Regan Spring 2010 Member of Cal Poly, Team 28-31, Regan Spring 2010
CPSU-REGAN-S10S28G31
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 3,084
