Audiovox CDM-8900 Camera Replacement
Aaron Shaw
Aaron Shaw and 12 other contributors
Last updated on May 29, 2024
15 minutes
Moderate
Needs Better Images
Inconsistent Images
Missing Steps
Introduction
Go to step 1
If the camera on your Audiovox CDM-8900 is not working correctly or showing a black screen when trying to use the camera, then you might need a camera replacement.
There is no need to purchase a new phone. Just replace the camera!
Step 6 requires you to take the motherboard and simply add the new camera carefully and verify that the camera is oriented correctly when reinserting.
Remember to carefully place everything back to its original place.
Tools
  1. Audiovox CDM-8900 Camera Replacement, Battery: step 1, image 1 of 2 Audiovox CDM-8900 Camera Replacement, Battery: step 1, image 2 of 2
    • Hold the phone in one hand, slide the latch up, and pull the battery up to remove it.
  2. Audiovox CDM-8900 Camera Replacement, Antenna: step 2, image 1 of 3 Audiovox CDM-8900 Camera Replacement, Antenna: step 2, image 2 of 3 Audiovox CDM-8900 Camera Replacement, Antenna: step 2, image 3 of 3
    • Grasp the antenna at its base and twist to unscrew.
    • Remove the antenna along with its plastic casing from inside the battery housing. Keep the antenna in the plastic casing for reassembly.
  3. Audiovox CDM-8900 Camera Replacement, Motherboard: step 3, image 1 of 3 Audiovox CDM-8900 Camera Replacement, Motherboard: step 3, image 2 of 3 Audiovox CDM-8900 Camera Replacement, Motherboard: step 3, image 3 of 3
    • Remove the small rubber insert from the top of the phone to access the top screw.
    • Unscrew all five screws on the back of the cell phone with a Phillips #00 screwdriver.
    • If screws do not slide out after unscrewing, gently flip and tap the phone in your hand until the screws come loose.
  4. Audiovox CDM-8900 Camera Replacement: step 4, image 1 of 3 Audiovox CDM-8900 Camera Replacement: step 4, image 2 of 3 Audiovox CDM-8900 Camera Replacement: step 4, image 3 of 3
    • Wedge the phone plate toward you, using the leverage from an opening tool.
    • The volume control button on the left side of the phone will loosen. Make sure to carefully reinsert it during reassembly.
    • Detach the motherboard from the LCD screen connector by gently detaching the small copper plate on the top right of the motherboard.
  5. Audiovox CDM-8900 Camera Replacement: step 5, image 1 of 3 Audiovox CDM-8900 Camera Replacement: step 5, image 2 of 3 Audiovox CDM-8900 Camera Replacement: step 5, image 3 of 3
    • To release the motherboard, push the large "OK" button located on the other side of the phone.
    • Before reassembly, make sure the keypad is lined up with the motherboard. Be sure the camera lens is properly aligned at the top of the motherboard and the volume controls are in place.
  6. Audiovox CDM-8900 Camera Replacement, Camera: step 6, image 1 of 1
    • Grasp camera.
    • Slide the camera out of slot on the logic board.
    • Camera is difficult to reassemble; there is a white clip for easy camera replacement. Verify that you orient the camera correctly when reinserting.
Aaron Shaw
168 Reputation
6 Guides authored
Cal Poly, Team 28-31, Regan Spring 2010 Member of Cal Poly, Team 28-31, Regan Spring 2010
CPSU-REGAN-S10S28G31
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 2,454
