Audiovox CDM-8900 Main LCD Screen Replacement
  1. Audiovox CDM-8900 Main LCD Screen Replacement, Main LCD Screen: step 1, image 1 of 2 Audiovox CDM-8900 Main LCD Screen Replacement, Main LCD Screen: step 1, image 2 of 2
    • Remove four screw covers using the spudger.
    • Because the bottom two screw covers are attached with an adhesive, you will not be able to replace them when you reassemble the phone.
  2. Audiovox CDM-8900 Main LCD Screen Replacement: step 2, image 1 of 2 Audiovox CDM-8900 Main LCD Screen Replacement: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the four Phillips #00 screws.
    • Tweezers may be useful for removing loosened screws.
  3. Audiovox CDM-8900 Main LCD Screen Replacement: step 3, image 1 of 3 Audiovox CDM-8900 Main LCD Screen Replacement: step 3, image 2 of 3 Audiovox CDM-8900 Main LCD Screen Replacement: step 3, image 3 of 3
    • The small electronic components inside the phone are fragile; take care not to damage them when completing this step.
    • Wedge one of the plastic opening tools under the phone cover near the hinge.
    • Insert the second plastic opening tool under the phone cover and slide it around the perimeter.
    • Detach the phone cover from the phone's base.
  4. Audiovox CDM-8900 Main LCD Screen Replacement: step 4, image 1 of 3 Audiovox CDM-8900 Main LCD Screen Replacement: step 4, image 2 of 3 Audiovox CDM-8900 Main LCD Screen Replacement: step 4, image 3 of 3
    • Slide out the two metal braces located along the sides of the LCD screen.
    • Carefully peel back the tape from both sides of the copper frame.
  5. Audiovox CDM-8900 Main LCD Screen Replacement: step 5, image 1 of 2 Audiovox CDM-8900 Main LCD Screen Replacement: step 5, image 2 of 2
    • Do not detach or tear any wires when completing this step.
    • Using the spudger, carefully separate the speaker and microphone from the inside surface of the phone.
    • The smaller black disc is glued down, so you may need to use some force to detach it. Both disks will still remain attached via wires.
  6. Audiovox CDM-8900 Main LCD Screen Replacement: step 6, image 1 of 2 Audiovox CDM-8900 Main LCD Screen Replacement: step 6, image 2 of 2
    • The copper frame is attached to the phone at the hinge. Do not tear the frame.
    • Gently lift the copper frame surrounding the LCD screen.
  7. Audiovox CDM-8900 Main LCD Screen Replacement: step 7, image 1 of 2 Audiovox CDM-8900 Main LCD Screen Replacement: step 7, image 2 of 2
    • With the copper screen lifted up, gently pull out the ribbon connector and lift out the LCD screen.
Aaron Shaw
159 Reputation
6 Guides authored
Cal Poly, Team 28-31, Regan Spring 2010 Member of Cal Poly, Team 28-31, Regan Spring 2010
CPSU-REGAN-S10S28G31
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 4,131
