Audiovox CDM-8910 Keyboard Replacement
  1. Audiovox CDM-8910 Keyboard Replacement, Antenna: step 1, image 1 of 1
    • Locate the antenna (shown in red box) at the top of the phone when closed.
  2. Audiovox CDM-8910 Keyboard Replacement: step 2, image 1 of 1
    • Using your thumb and index finger, grip the antenna near its base and unscrew counter clockwise. Once loose, remove the antenna by pulling it from its insert hole.
  3. Audiovox CDM-8910 Keyboard Replacement, Battery: step 3, image 1 of 1
    • Locate the back side of the phone.
    • The battery is the large main compartment (red box).
  4. Audiovox CDM-8910 Keyboard Replacement: step 4, image 1 of 1
    • Use your finger to slide the latch (circled) upwards.
    • While holding the latch up, pull the battery off the phone.
  5. Audiovox CDM-8910 Keyboard Replacement: step 5, image 1 of 1
    • The back of the phone will look like this when the battery is correctly removed.
  6. Audiovox CDM-8910 Keyboard Replacement, Rear Case: step 6, image 1 of 1
    • Peel the rubber indicated toward the top of the phone
  7. Audiovox CDM-8910 Keyboard Replacement: step 7, image 1 of 1
    • Remove the screw that sits underneath the rubber covering.
  8. Audiovox CDM-8910 Keyboard Replacement: step 8, image 1 of 1
    • Remove the five (5) total screws using a Philips head screwdriver.
  9. Audiovox CDM-8910 Keyboard Replacement: step 9, image 1 of 1
    • Use spudger and insert it towards the bottom of the phone as pictured.
    • Carefully working yourself around the phone with the spudger, pry it open. This may require a bit of force.
    • The volume control button will be loose, so make sure to take it out once the rear case is fully removed.
  10. Audiovox CDM-8910 Keyboard Replacement: step 10, image 1 of 1
    • The back case should now be completely removed and the motherboard will be visible.
  11. Audiovox CDM-8910 Keyboard Replacement, Motherboard: step 11, image 1 of 3 Audiovox CDM-8910 Keyboard Replacement, Motherboard: step 11, image 2 of 3 Audiovox CDM-8910 Keyboard Replacement, Motherboard: step 11, image 3 of 3
    • Disconnect the gold connection patch
    • Use a spudger or finger to disconnect the piece.
  12. Audiovox CDM-8910 Keyboard Replacement: step 12, image 1 of 1
    • Using a spudger, lift the motherboard out of the phone case as pictured.
  13. Audiovox CDM-8910 Keyboard Replacement: step 13, image 1 of 1
    • The motherboard should now be completely removed from the phone.
  14. Audiovox CDM-8910 Keyboard Replacement, Keyboard: step 14, image 1 of 1
    • Once the motherboard has been removed, peel the keyboard as pictured.
Carlos Guerrero
1 Reputation
2 Guides authored
Cal Poly, Team 3-24, Regan Fall 2010 Member of Cal Poly, Team 3-24, Regan Fall 2010
CPSU-REGAN-F10S3G24
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 1,502
