Audiovox CDM-8910 LCD Screen Replacement
  1. Audiovox CDM-8910 LCD Screen Replacement, LCD Screen: step 1, image 1 of 1
    • With phone in the flipped-open position, use a spudger to remove the four (4) rubber pads (one shown in red circle) located near the corners of the face with the LCD screen.
  2. Audiovox CDM-8910 LCD Screen Replacement: step 2, image 1 of 1
    • Use a small Phillips head screwdriver to remove the four (4) screws exposed by removed rubber pads.
  3. Audiovox CDM-8910 LCD Screen Replacement: step 3, image 1 of 1
    • Use a spudger to pry the front cover off of the phone, gradually working your way around the front face.
  4. Audiovox CDM-8910 LCD Screen Replacement: step 4, image 1 of 1
    • Use a spudger to lift away and remove the metallic frame (in blue).
    • Use the spudger to lift away the two electrical contacts (in red).
    • Use the spudger to lift away the speaker (in yellow).
  5. Audiovox CDM-8910 LCD Screen Replacement: step 5, image 1 of 1
    • This is what the rear of the LCD screen should look like before proceeding. Note all necessary connections are undone.
  6. Audiovox CDM-8910 LCD Screen Replacement: step 6, image 1 of 1
    • Use a spudger to lift away the LCD screen.
  7. Audiovox CDM-8910 LCD Screen Replacement: step 7, image 1 of 1
    • LCD screen successfully removed!
Kevin Jafarey
11 Reputation
2 Guides authored
Cal Poly, Team 3-24, Regan Fall 2010 Member of Cal Poly, Team 3-24, Regan Fall 2010
CPSU-REGAN-F10S3G24
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 2,922
