Audiovox CR8030iE5 Top-Casing Replacement
  1. Audiovox CR8030iE5 Top-Casing Replacement, Top-Casing: step 1, image 1 of 1
    • Turn the device upside down.
    • Apply constant pressure to the base of your Audiovox, while holding the plastic casing until the casing is completely removed.
  2. Audiovox CR8030iE5 Top-Casing Replacement: step 2, image 1 of 1
    • Remove the four screws from the base using a Phillips #1 screwdriver.
  3. Audiovox CR8030iE5 Top-Casing Replacement: step 3, image 1 of 1
    • Turn the device right-side up.
    • Gently pull the top panel off of the device.
  4. Audiovox CR8030iE5 Top-Casing Replacement: step 4, image 1 of 1
    • Using a Phillips #1 screwdriver, remove the screw found in the middle of the board.
  5. Audiovox CR8030iE5 Top-Casing Replacement: step 5, image 1 of 1
    • Pull back the board gently to avoid disconnecting the attached wires.
    • This allows you to view the soldered connections on the other side, and the internal components.
Savannah Smith
51 Reputation
2 Guides authored
Cal Poly, Team 10-39, Amido Spring 2013 Member of Cal Poly, Team 10-39, Amido Spring 2013
CPSU-AMIDO-S13S10G39
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 346
