August Smart Lock Accelerometer Replacement
  1. August Smart Lock Accelerometer Replacement, Accelerometer: step 1, image 1 of 3 August Smart Lock Accelerometer Replacement, Accelerometer: step 1, image 2 of 3 August Smart Lock Accelerometer Replacement, Accelerometer: step 1, image 3 of 3
    • Flip device over so the black bottom is facing you.
    • Undo latches on both sides to remove the metal cover.
    • Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
    • To unscrew all of the screws, you will need to close the latches again.
    • When you lift off the cover, be careful not to lift to far up. The cover contains the speaker which is connected to the motherboard.
  2. August Smart Lock Accelerometer Replacement: step 2, image 1 of 3 August Smart Lock Accelerometer Replacement: step 2, image 2 of 3 August Smart Lock Accelerometer Replacement: step 2, image 3 of 3
    • Grab the gears and lift them up to remove from the device
  3. August Smart Lock Accelerometer Replacement: step 3, image 1 of 3 August Smart Lock Accelerometer Replacement: step 3, image 2 of 3 August Smart Lock Accelerometer Replacement: step 3, image 3 of 3
    • Remove the (3) three silver screws by the motor using a Phillips #0 screwdriver.
    • Disconnect the speaker plug from the motherboard
    • Disconnect the battery plugs from the motherboard.
  4. August Smart Lock Accelerometer Replacement: step 4, image 1 of 1
    • Once the speaker is disconnected, remove the back cover.
    • Lift up the motherboard and motor assembly out of the device.
  5. August Smart Lock Accelerometer Replacement: step 5, image 1 of 2 August Smart Lock Accelerometer Replacement: step 5, image 2 of 2
    • Locate the Accelerometer. It is attached to the motherboard by a ribbon.
    • Lift up the black tab to remove the ribbon from the motherboard.
7 other people completed this guide.
William Fink
766 Reputation
3 Guides authored
USF Tampa, Team S11-G6, Passmore Fall 2017 Member of USF Tampa, Team S11-G6, Passmore Fall 2017
USFT-PASSMORE-F17S11G6
4 Members
3 Guides authored
7 Comments
Any idea where can I get a new accelerometer to complete this repair?
Thai Nguyen - Reply
Where can we get a new accelerometer. My phone was not connecting because of the ribbon was broken inside
Dinesh Sharma - Reply
Same as aboveā€¦. where to locate an accelerometer??
osallabe - Reply
Did anyone find out where to buy the part?
LBurd - Reply
Where can I find one
Jeff Wasilewski - Reply
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 51
All Time: 7,713
