August Smart Lock Gear Replacement
  1. August Smart Lock Gear Replacement, Gear: step 1, image 1 of 3 August Smart Lock Gear Replacement, Gear: step 1, image 2 of 3 August Smart Lock Gear Replacement, Gear: step 1, image 3 of 3
    • Flip the device over so the metal plate is facing you.
    • Undo the latches on the side to remove the metal plate.
    • Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
    • To unscrew all of the screws, you will need to close the latches again.
    • Do not pull the cover apart too far as the speaker is in the cover and connected to the motherboard.
  2. August Smart Lock Gear Replacement: step 2, image 1 of 3 August Smart Lock Gear Replacement: step 2, image 2 of 3 August Smart Lock Gear Replacement: step 2, image 3 of 3
    • Lift the cover off the device and set to the side.
    • The cover contains the speaker which is connected to the motherboard so do not pull to far apart.
    • Remove the gears as shown.
12 other people completed this guide.
William Fink
814 Reputation
3 Guides authored
USF Tampa, Team S11-G6, Passmore Fall 2017 Member of USF Tampa, Team S11-G6, Passmore Fall 2017
USFT-PASSMORE-F17S11G6
4 Members
3 Guides authored
8 Guide Comments
The tittle of this topic is: August Smart Lock Gear Replacement, but I don't see any spare part replacement at all!
Walter Quintero - Reply
Any tips on where to get replacement gears?
Byron H - Reply
The gear connecting the motor is cracked. I'd also like to know where to get parts other than buying another broken August lock that's broken in another way.
Robert F. Jobin Jr. - Reply
Robert, where you able to find this replacement gear? Mine broke this week and having a hard time to find the part. Thanks
Luiz Cavalcante -
Anyone find gear replacements? The. Am on the motor shaft cracked on mine
pennytrotz - Reply
Past 24 Hours: 5
Past 7 Days: 17
Past 30 Days: 64
All Time: 13,611
