Auking M8-F PCB Button Panel Replacement
  1. Auking M8-F PCB Button Panel Replacement, PCB Button Panel: step 1, image 1 of 2 Auking M8-F PCB Button Panel Replacement, PCB Button Panel: step 1, image 2 of 2
    • Make sure that the device is unplugged from any power source before attempting any repairs.
    • Flip the projector on its opposite side.
    • Remove all six of the 11 mm screws using a Phillips #1 screwdriver.
    • Remove the two 14 mm screws using a Phillips #1 screwdriver.
  2. Auking M8-F PCB Button Panel Replacement: step 2, image 1 of 2 Auking M8-F PCB Button Panel Replacement: step 2, image 2 of 2
    • Carefully prop open the top of the projector.
    • Disconnect the cable attached to the top lid.
    • Remove the top lid.
  3. Auking M8-F PCB Button Panel Replacement: step 3, image 1 of 2 Auking M8-F PCB Button Panel Replacement: step 3, image 2 of 2
    • Remove the wire cord attached to the top panel to separate both the top panel and the wire cord.
  4. Auking M8-F PCB Button Panel Replacement: step 4, image 1 of 3 Auking M8-F PCB Button Panel Replacement: step 4, image 2 of 3 Auking M8-F PCB Button Panel Replacement: step 4, image 3 of 3
    • Remove six of the 5 mm screws using a Phillips #00 screwdriver to detach the power panel.
    • Remove the power panel.
Aubrey Haynes
286 Reputation
3 Guides authored
1 Guide Comment
I have a problem not covered here.
When I power up, only a red light is lit. Any ideas?
sasquachnw@duck.com
sasquachnw - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 237
