Automatic Tommy 20 Ammo Drum Replacement
Moira Foster
Moira Foster and 2 other contributors
Last updated on December 26, 2014
5 - 10 minutes
Easy
Introduction
Go to step 1
This guide will help teach you how to remove and replace the drum of the gun that holds your darts. This require splitting the gun into two halves and requires a #00 Phillips head screwdriver, but is otherwise fairly simple. Just follow the steps and get your gun back into fighting shape!
Tools
  1. Automatic Tommy 20 Ammo Drum Replacement, Splitting the Gun into Two Halves: step 1, image 1 of 2 Automatic Tommy 20 Ammo Drum Replacement, Splitting the Gun into Two Halves: step 1, image 2 of 2
    • Locate the orange slider on the front side of the gun.
    • Pull the orange slider towards the back of the gun while lifting up on the nose the gun.
  2. Automatic Tommy 20 Ammo Drum Replacement: step 2, image 1 of 3 Automatic Tommy 20 Ammo Drum Replacement: step 2, image 2 of 3 Automatic Tommy 20 Ammo Drum Replacement: step 2, image 3 of 3
    • Remove the single 1/8 in. screw at the junction of the body and the nose using a Philips #00 Screwdriver.
    • Remove all parts within the chamber to be able to completely detach the nose of the gun.
    • Be careful to keep track of all the components for reassembly.
  3. Automatic Tommy 20 Ammo Drum Replacement, Ammo Drum: step 3, image 1 of 3 Automatic Tommy 20 Ammo Drum Replacement, Ammo Drum: step 3, image 2 of 3 Automatic Tommy 20 Ammo Drum Replacement, Ammo Drum: step 3, image 3 of 3
    • Remove the 1/16 in. screws using a Phillips #00 Screwdriver as indicated in the photo on the left.
    • Remove the 1 mm screw on the battery lid using a Philips #1 Screwdriver as indicated in the photo on the left.
  4. Automatic Tommy 20 Ammo Drum Replacement: step 4, image 1 of 1
    • Carefully spread apart the two halves of the gun, and lift out the ammo drum.
3 other people completed this guide.
Moira Foster
419 Reputation
3 Guides authored
Cal Poly, Team 6-22, Maness Fall 2014 Member of Cal Poly, Team 6-22, Maness Fall 2014
CPSU-MANESS-F14S6G22
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 819
