Automatic Tommy 20 Battery Replacement
  1. Automatic Tommy 20 Battery Replacement, Removing the Battery Cover: step 1, image 1 of 2 Automatic Tommy 20 Battery Replacement, Removing the Battery Cover: step 1, image 2 of 2
    • Remove the single 1mm screw connecting the battery cover to the gun using a Phillips #1 screwdriver.
    • Lift the cover away from the gun and remove.
  2. Automatic Tommy 20 Battery Replacement, Remove the Batteries: step 2, image 1 of 2 Automatic Tommy 20 Battery Replacement, Remove the Batteries: step 2, image 2 of 2
    • Remove all three batteries from compartment by pulling up on the positive end of each battery.
Reed Garmsen
468 Reputation
2 Guides authored
Cal Poly, Team 6-22, Maness Fall 2014 Member of Cal Poly, Team 6-22, Maness Fall 2014
CPSU-MANESS-F14S6G22
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 799
