1. Turn on the autosampler. Screen will read "...STANDBY..."
2. Press "ENTER/PROGRAM" button. Use arrows to highlight "CONFIGURE". Press "ENTER/PROGRAM" button
3. Press "ENTER/PROGRAM" to "SET CLOCK". Use the numeric keys to set the time and date. You can use the arrows to move. When finished. Press "ENTER/PROGRAM" button.
4. Press "ENTER/PROGRAM" to configure "BOTTLES AND SIZES".
Use arrows to select "PORTABLE" sampler. Press "ENTER/PROGRAM" to configure bottles and sizes.
Use arrows to select "24" botles. Press "ENTER/PROGRAM" button.
Use numeric keys to enter "1000" mL for the "BOTTLE VOLUME". Press "ENTER/PROGRAM" button.
5. Press "ENTER/PROGRAM" to configure "SUCTION LINE".
Use arrow to select "3/8" inch for "SUCTION LINE I.D." Press "ENTER/PROGRAM" button.
Use arrow to select "VINYL" for "SUCTION LINE" type. Press "ENTER/PROGRAM" button.
Use numeric keys to enter "25" feet for "SUCTION LINE LENGTH". Press "ENTER/PROGRAM" button.
6. Press "ENTER/PROGRAM" button to configure "LIQUID DETECTOR".
Use arrows to select "ENABLE" "LIQUID DECTOR". Press "ENTER/PROGRAM" button.
Use numeric keys to enter "3" "RINSE CYCLES." Press "ENTER/PROGRAM" button.
Screen will read "ENTER HEAD MANUALLY?" Use arrows to select "NO". Press "ENTER/PROGRAM" button.
Screen will read "RETRY UP TO X TIMES WHEN SAMPLING?" Use numeric keys to enter "3". Press "ENTER/PROGRAM" button.
7. Press "ENTER/PROGRAM" to configure "PROGRAMMING MODE".
Use arrows to select "BASIC" mode. Press "ENTER/PROGRAM" button.
8. Press "ENTER/PROGRAM" to configure "CALIBRATE SAMPLER".
Use arrows to select "DISABLE" "CALIBRATE SAMPLER". Press "ENTER/PROGRAM" button.
9. Press "ENTER/PROGRAM" to configure "START TIME DELAY". Press "ENTER/PROGRAM" button.
Screen will read "X MINUTE DELAY TO START." Use numeric keys to enter "0" minutes. Press "ENTER/PROGRAM" button.
10. Press "ENTER/PROGRAM" to configure "ENABLE PIN". Press "ENTER/PROGRAM" button.
Use arrow to select "NO" for "MASTER/SLAVE MODE?" Press "ENTER/PROGRAM" button.
Use arrow to select "NO" for "SAMPLE UPON DISABLE?" Press "ENTER/PROGRAM" button.
Use arrow to select "NO" for "SAMPLE UPON ENABLE?" Press "ENTER/PROGRAM" button.
Use arrow to select "NO" for "RESET SAMPLE INTERVAL?" Press "ENTER/PROGRAM" button.
Use arrow to select "NO" for "INHIBIT COUNTDOWN?" Press "ENTER/PROGRAM" button.
11. Press "ENTER/PROGRAM" to configure "EVENT MARK". Press "ENTER/PROGRAM" button.
Use arrow to select "CONTINUOUS SIGNAL". Press "ENTER/PROGRAM" button.
Use arrow to select "PUMP CYCLE". Press "ENTER/PROGRAM" button.
12. Press "ENTER/PROGRAM" to configure "PURGE COUNTS". Press "ENTER/PROGRAM" button.
Use numeric keys to enter "XX" for "PRE-SAMPLE COUNTS". Press "ENTER/PROGRAM" button.
Use numeric keys to enter "XX" for "POST-SAMPLE COUNTS". Press "ENTER/PROGRAM" button.
12. Press "ENTER/PROGRAM" to configure "TUBING LIFE". Press "ENTER/PROGRAM" button.
Screen will read "X PUMP COUNTS, WARNING AT XXX000". Press "ENTER/PROGRAM" button.
Use arrows to select "NO" for "RESET PUMP COUNTER?". Press "ENTER/PROGRAM" button.
Use numeric keys to enter "XXX000" for "PUMP COUNTS TO WARNING". Press "ENTER/PROGRAM" button.
13. Press "ENTER/PROGRAM" to configure "PROGRAM LOCK". Press "ENTER/PROGRAM" button.
Use arrows to select "DISABLE" "PROGRAM LOCK". Press "ENTER/PROGRAM" button.
15. The next configuration option is "SAMPLER ID". Skip this configuration step by using the arrows.
16. The next configuration option is "RUN DIAGNOSTICS". Skip this configuration step by using the arrows.
2 other people completed this guide.
