Axess SPBT1031 Red Interface Plate Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Axess SPBT1031 Red Interface Plate Replacement, Red Interface Plate: step 1, image 1 of 1
    • Use a metal spudger to remove the mesh speaker covers (the side with the buttons) by wedging the narrow end into the center of the outer edge of the mesh, touching the red plate.
  2. Axess SPBT1031 Red Interface Plate Replacement: step 2, image 1 of 1
    • Remove the four 5 mm screws from the red panel under the mesh using a Phillips #1 screwdriver.
  3. Axess SPBT1031 Red Interface Plate Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • If the screws are difficult to remove, use a pair of tweezers to twist and pick them out.
  4. Axess SPBT1031 Red Interface Plate Replacement: step 4, image 1 of 1
    • Separate the red interface plate from the black face plate by pulling them apart.
Michael Bradley
510 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 79
