Azpen A701 Battery Replacement
  1. Azpen A701 Battery Replacement, General Disassembly Prerequisite Guide: step 1, image 1 of 1
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
  2. Azpen A701 Battery Replacement: step 2, image 1 of 2 Azpen A701 Battery Replacement: step 2, image 2 of 2
    • Pry open back piece with plastic spudger.
    • Remove the back piece of the device.
    • The back panel may be difficult to pry off, use gentle force.
  3. Azpen A701 Battery Replacement: step 3, image 1 of 1
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
  4. Azpen A701 Battery Replacement: step 4, image 1 of 1
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
  5. Azpen A701 Battery Replacement, Battery: step 5, image 1 of 1
    • Remove red and black wires leading from the battery to the motherboard by heating up a soldering iron and applying to area and gently removing wires.
    • For more information on soldering, please refer to iFixit's guide here.
  6. Azpen A701 Battery Replacement: step 6, image 1 of 1
    • Insert new battery by soldering red and black wires onto the motherboard.
    • Make sure to solder the wires back on in the correct configuration (as pictured).
Grant Harding
249 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 718
