Azpen A701 Charger Port Replacement
  1. Azpen A701 Charger Port  Replacement, General Disassembly Prerequisite Guide: step 1, image 1 of 1
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
  2. Azpen A701 Charger Port  Replacement: step 2, image 1 of 2 Azpen A701 Charger Port  Replacement: step 2, image 2 of 2
    • Pry open back piece with plastic spudger.
    • Remove the back piece of the device.
    • The back panel may be difficult to pry off, use gentle force.
  3. Azpen A701 Charger Port  Replacement: step 3, image 1 of 1
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
  4. Azpen A701 Charger Port  Replacement: step 4, image 1 of 1
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
  5. Azpen A701 Charger Port  Replacement, Charger Port: step 5, image 1 of 1
    • The charger port is located on the underside of the motherboard (as pictured).
  6. Azpen A701 Charger Port  Replacement: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the charger port by using tweezers and gently pulling.
  7. Azpen A701 Charger Port  Replacement: step 7, image 1 of 1
    • Solder and place new charger port.
To reassemble your device, snap back piece on to the front piece and screw in both 2cm screws at the bottom.
Michael
568 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 584
