Azpen A701 General Disassembly Prerequisite Guide Replacement
  1. Azpen A701 General Disassembly Prerequisite Guide Replacement, General Disassembly Prerequisite Guide: step 1, image 1 of 1
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
  2. Azpen A701 General Disassembly Prerequisite Guide Replacement: step 2, image 1 of 2 Azpen A701 General Disassembly Prerequisite Guide Replacement: step 2, image 2 of 2
    • Pry open back piece with plastic spudger.
    • Remove the back piece of the device.
    • The back panel may be difficult to pry off, use gentle force.
  3. Azpen A701 General Disassembly Prerequisite Guide Replacement: step 3, image 1 of 1
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
  4. Azpen A701 General Disassembly Prerequisite Guide Replacement: step 4, image 1 of 1
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
Michael
568 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 370
