Azpen A701 Screen Replacement
  1. Azpen A701 Screen Replacement, General Disassembly Prerequisite Guide: step 1, image 1 of 1
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
  2. Azpen A701 Screen Replacement: step 2, image 1 of 2 Azpen A701 Screen Replacement: step 2, image 2 of 2
    • Pry open back piece with plastic spudger.
    • Remove the back piece of the device.
    • The back panel may be difficult to pry off, use gentle force.
  3. Azpen A701 Screen Replacement: step 3, image 1 of 1
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
  4. Azpen A701 Screen Replacement: step 4, image 1 of 1
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
  5. Azpen A701 Screen Replacement, Screen: step 5, image 1 of 3 Azpen A701 Screen Replacement, Screen: step 5, image 2 of 3 Azpen A701 Screen Replacement, Screen: step 5, image 3 of 3
    • Disconnect the two larger of the three ZIF cables by prying open the flap with a plastic spudger and gently removing the cable.
  6. Azpen A701 Screen Replacement: step 6, image 1 of 1
    • Peel off the black tape from the corner of the motherboard (indicated by the blue surface of the device)
  7. Azpen A701 Screen Replacement: step 7, image 1 of 3 Azpen A701 Screen Replacement: step 7, image 2 of 3 Azpen A701 Screen Replacement: step 7, image 3 of 3
    • Use PH000 Phillips head screw driver to remove the three screws that connect the motherboard to the front panel.
    • When removing the motherboard be cautious of the gray wire connected from motherboard to actual device.
  8. Azpen A701 Screen Replacement: step 8, image 1 of 1
    • Remove motherboard and battery and set aside.
  9. Azpen A701 Screen Replacement: step 9, image 1 of 3 Azpen A701 Screen Replacement: step 9, image 2 of 3 Azpen A701 Screen Replacement: step 9, image 3 of 3
    • Remove the small orange tape attached with a gray wire from the top corner of the device. This is the antenna.
    • Use plastic spudger around silver lining within the device to pry the screen off.
    • The metal screen assembly is two pieces. When removing the screen, make sure to pry off both pieces at once.
  10. Azpen A701 Screen Replacement: step 10, image 1 of 1
    • Replace broken screen and reverse steps to re-assemble device.
Michael
568 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 553
