BIOS battery replacement
  1. BIOS battery replacement, Battery: step 1, image 1 of 3 BIOS battery replacement, Battery: step 1, image 2 of 3 BIOS battery replacement, Battery: step 1, image 3 of 3
    • Unlock the battery latch on the right.
    • Unlock the battery lock on the left.
    • Remove the battery pack from its slot.
  2. BIOS battery replacement, Access to Components 1: step 2, image 1 of 3 BIOS battery replacement, Access to Components 1: step 2, image 2 of 3 BIOS battery replacement, Access to Components 1: step 2, image 3 of 3
    • Using the Philips # 0 screwdriver, unscrew the 2 screws from the bottom cover.
    • Check the marks indicating the direction in which the cover must be removed.
    • Remove the bottom cover by removing it in the direction of the markers.
  3. BIOS battery replacement: step 3, image 1 of 1
    • HDD hard disk and BIOS stack components appear.
  4. BIOS battery replacement, BIOS battery: step 4, image 1 of 2 BIOS battery replacement, BIOS battery: step 4, image 2 of 2
    • Remove the battery connector first.
    • Then gently peel off the BIOS stack itself.
For reassembly, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
33,538 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 95
All Time: 1,391
