BLU Dash Music 4.0 Headphone Jack Replacement
  1. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Back Cover: step 1, image 1 of 1
    • Use the plastic opening tool or your fingernail to pry off the back cover.
  2. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Battery: step 2, image 1 of 1
    • Use the plastic opening tool or your fingernail to pry off the battery from the top right corner.
  3. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Screws: step 3, image 1 of 2 BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Screws: step 3, image 2 of 2
    • Use a screwdriver to remove each of the four screws.
  4. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Inner Cover: step 4, image 1 of 2 BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Inner Cover: step 4, image 2 of 2
    • Take the plastic opening tool and insert it in the crease between the front screen and the inner back cover.
    • Slide the plastic opening tool along the edge of the phone to pry the two covers apart.
  5. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Black Pad: step 5, image 1 of 2 BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Black Pad: step 5, image 2 of 2
    • Insert the plastic opening tool between the black pad and the circuit board. Then gently pry off the black pad.
    • This will make the connections of the charging port more accessible.
  6. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Solder Connections: step 6, image 1 of 2 BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Solder Connections: step 6, image 2 of 2
    • Using a soldering iron and a pair of pliers, melt the soldering connections around the headphone jack.
    • Quickly pull off the current headphone jack while the soldering connections are still soft.
  7. BLU Dash Music 4.0 Headphone Jack Replacement, Mount the New Headphone Jack: step 7, image 1 of 1
    • Mount the new headphone jack such that the prongs of the headphone jack line up with the soldering connections.
    • Using a soldering iron, solder the connections in place.
Lioma Terrero Soto
525 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 423
