BLU Energy X Battery Replacement
  1. BLU Energy X Battery Replacement, Battery: step 1, image 1 of 3 BLU Energy X Battery Replacement, Battery: step 1, image 2 of 3 BLU Energy X Battery Replacement, Battery: step 1, image 3 of 3
    • Remove the back case using plastic opening tool.
  2. BLU Energy X Battery Replacement: step 2, image 1 of 2 BLU Energy X Battery Replacement: step 2, image 2 of 2
    • Remove the seven 4mm Phillips #000 screws.
    • Remove the top plate.
  3. BLU Energy X Battery Replacement: step 3, image 1 of 3 BLU Energy X Battery Replacement: step 3, image 2 of 3 BLU Energy X Battery Replacement: step 3, image 3 of 3
    • Detach the battery from the mother board using a plastic opening tool.
    • Use a plastic spudger to remove battery.
4 other people completed this guide.
Sishun Wang
630 Reputation
4 Guides authored
USF Tampa, Team 12-2, Eyestone Spring 2016 Member of USF Tampa, Team 12-2, Eyestone Spring 2016
USFT-EYESTONE-S16S12G2
3 Members
5 Guides authored
2 Guide Comments
Hi. I my short Band Aid q makes connection between the battery and cell .. q do ? They are fixable ?
tamara diale - Reply
directions were pretty straightforward... mine had a tiny sticker w/ the "B" in BLU printed, covering the screw on the upper left corner that needed removal (warranty?). otherwise, simple replacement...thanks!
joe doe (ch555x) - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 12
All Time: 2,174
