BLU Energy X Motherboard Replacement
  1. BLU Energy X Motherboard Replacement, Battery: step 1, image 1 of 3 BLU Energy X Motherboard Replacement, Battery: step 1, image 2 of 3 BLU Energy X Motherboard Replacement, Battery: step 1, image 3 of 3
    • Remove the back case using plastic opening tool.
  2. BLU Energy X Motherboard Replacement: step 2, image 1 of 2 BLU Energy X Motherboard Replacement: step 2, image 2 of 2
    • Remove the seven 4mm Phillips #000 screws.
    • Remove the top plate.
  3. BLU Energy X Motherboard Replacement: step 3, image 1 of 3 BLU Energy X Motherboard Replacement: step 3, image 2 of 3 BLU Energy X Motherboard Replacement: step 3, image 3 of 3
    • Detach the battery from the mother board using a plastic opening tool.
    • Use a plastic spudger to remove battery.
  4. BLU Energy X Motherboard Replacement, Motherboard: step 4, image 1 of 2 BLU Energy X Motherboard Replacement, Motherboard: step 4, image 2 of 2
    • Use the flat end of a spudger to flip up the black retaining flap on the ZIF connector.
  5. BLU Energy X Motherboard Replacement: step 5, image 1 of 2 BLU Energy X Motherboard Replacement: step 5, image 2 of 2
    • Gently pull the ribbon cable free of the ZIF connector.
  6. BLU Energy X Motherboard Replacement: step 6, image 1 of 2 BLU Energy X Motherboard Replacement: step 6, image 2 of 2
    • Gently peel up the antenna.
    • This is secured with some light adhesive, so some force may be required.
  7. BLU Energy X Motherboard Replacement: step 7, image 1 of 3 BLU Energy X Motherboard Replacement: step 7, image 2 of 3 BLU Energy X Motherboard Replacement: step 7, image 3 of 3
    • Gently rotate the motherboard up so that the front-facing camera is pointed towards you.
    • Use the pointed end of a spudger to disconnect the antenna cable and the ribbon cable.
  8. BLU Energy X Motherboard Replacement: step 8, image 1 of 2 BLU Energy X Motherboard Replacement: step 8, image 2 of 2
    • Lift the motherboard up and out of the device.
Geoff Wacker
90,313 Reputation
89 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 428
