BLU Energy X USB Board Replacement
  1. BLU Energy X USB Board Replacement, Battery: step 1, image 1 of 3 BLU Energy X USB Board Replacement, Battery: step 1, image 2 of 3 BLU Energy X USB Board Replacement, Battery: step 1, image 3 of 3
    • Remove the back case using plastic opening tool.
  2. BLU Energy X USB Board Replacement: step 2, image 1 of 2 BLU Energy X USB Board Replacement: step 2, image 2 of 2
    • Remove the seven 4mm Phillips #000 screws.
    • Remove the top plate.
  3. BLU Energy X USB Board Replacement: step 3, image 1 of 3 BLU Energy X USB Board Replacement: step 3, image 2 of 3 BLU Energy X USB Board Replacement: step 3, image 3 of 3
    • Detach the battery from the mother board using a plastic opening tool.
    • Use a plastic spudger to remove battery.
  4. BLU Energy X USB Board Replacement, USB Board: step 4, image 1 of 2 BLU Energy X USB Board Replacement, USB Board: step 4, image 2 of 2
    • Remove the five 4 mm JIS J000 screws from bottom plate
    • Remove the bottom casing.
  5. BLU Energy X USB Board Replacement: step 5, image 1 of 2 BLU Energy X USB Board Replacement: step 5, image 2 of 2
    • Disconnect vibration motor and connector as indicated.
    • Remove motherboard.
2 other people completed this guide.
Jeanine Sam
211 Reputation
1 Guide authored
USF Tampa, Team 12-2, Eyestone Spring 2016 Member of USF Tampa, Team 12-2, Eyestone Spring 2016
USFT-EYESTONE-S16S12G2
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 549
