BLU Energy X Vibration Motor Replacement
  1. BLU Energy X Vibration Motor Replacement, Battery: step 1, image 1 of 3 BLU Energy X Vibration Motor Replacement, Battery: step 1, image 2 of 3 BLU Energy X Vibration Motor Replacement, Battery: step 1, image 3 of 3
    • Remove the back case using plastic opening tool.
  2. BLU Energy X Vibration Motor Replacement: step 2, image 1 of 2 BLU Energy X Vibration Motor Replacement: step 2, image 2 of 2
    • Remove the seven 4mm Phillips #000 screws.
    • Remove the top plate.
  3. BLU Energy X Vibration Motor Replacement: step 3, image 1 of 3 BLU Energy X Vibration Motor Replacement: step 3, image 2 of 3 BLU Energy X Vibration Motor Replacement: step 3, image 3 of 3
    • Detach the battery from the mother board using a plastic opening tool.
    • Use a plastic spudger to remove battery.
  4. BLU Energy X Vibration Motor Replacement, Vibration Motor: step 4, image 1 of 3 BLU Energy X Vibration Motor Replacement, Vibration Motor: step 4, image 2 of 3 BLU Energy X Vibration Motor Replacement, Vibration Motor: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the five 4 mm JIS J000 screws from bottom plate
    • Using a soldering iron, simultaneously heat the two soldered connections for the motor
    • When the connection is melted, use a set of tweezers to safely remove the motor
2 other people completed this guide.
Sishun Wang
630 Reputation
4 Guides authored
USF Tampa, Team 12-2, Eyestone Spring 2016 Member of USF Tampa, Team 12-2, Eyestone Spring 2016
USFT-EYESTONE-S16S12G2
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 276
