Introduction
One of the most common problems that smartphone users experience is a cracked screen. This guide will describe how to remove the screen of the BLU Life XL phone from the rear housing. Since the screen is very brittle, make sure that the front surface of the screen is taped with clear scotch tape to keep breaking to a minimum.
Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
Remove the rear cover using your hands at the lip on the device back cover. No tools required.
Remove the battery by lifting the lower edge of the battery up first.
Remove the two 12x3mm screws using the Phillips #000 screwdriver.
Remove the ribbon cables.
To remove the screen, insert the spudger between the screen and the back housing. Run the spudger along the edge of the screen and gently pry it apart.
This is what the separated screen/digitizer and rear housing should look like. The first image shows the inside surfaces of both and the second image shows the outside surfaces.
This is the inside face of the digitizer.
This is the inside face of the rear housing.
This is the outside face of the screen.
This is the outside face of the rear housing.
