BLU Life XL Volume Control Buttons Replacement
  1. BLU Life XL Volume Control Buttons Replacement, Volume Control Buttons: step 1, image 1 of 3 BLU Life XL Volume Control Buttons Replacement, Volume Control Buttons: step 1, image 2 of 3 BLU Life XL Volume Control Buttons Replacement, Volume Control Buttons: step 1, image 3 of 3
    • Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
    • Remove the rear cover using your hands at the lip on the device back cover. No tools required.
    • Remove the battery by lifting the lower edge of the battery up first.
  2. BLU Life XL Volume Control Buttons Replacement: step 2, image 1 of 2 BLU Life XL Volume Control Buttons Replacement: step 2, image 2 of 2
    • Remove the 12x3mm screws from the rear plate using the Phillips#000 screwdriver.
  3. BLU Life XL Volume Control Buttons Replacement: step 3, image 1 of 2 BLU Life XL Volume Control Buttons Replacement: step 3, image 2 of 2
    • Firmly press the prying tool into the gap between the front glass and rear plate. This gap is located on all sides of the phone.
    • Run the prying tool around the entire phone separating the rear plate from the frame.
  4. BLU Life XL Volume Control Buttons Replacement: step 4, image 1 of 3 BLU Life XL Volume Control Buttons Replacement: step 4, image 2 of 3 BLU Life XL Volume Control Buttons Replacement: step 4, image 3 of 3
    • Gently remove the tape covering the volume control buttons. The tape is located near the top left of the cavity for the battery.
    • Replace the component and reapply the tape over the buttons.
James Whitlow
342 Reputation
3 Guides authored
USF Tampa, Team S2-G5, Eyestone Spring 2018 Member of USF Tampa, Team S2-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S2G5
3 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 8
All Time: 404
