BLU R2 Plus Fingerprint Sensor Replacement
  1. BLU R2 Plus Fingerprint Sensor Replacement, Power Off: step 1, image 1 of 1
    • Be sure that your BLU R2 Plus is completely powered off and has less than 25% battery left. This will lower the chance of your battery catching fire and your logic board/motherboard shorting out.
  2. BLU R2 Plus Fingerprint Sensor Replacement, Releasing the Back Cover: step 2, image 1 of 3 BLU R2 Plus Fingerprint Sensor Replacement, Releasing the Back Cover: step 2, image 2 of 3 BLU R2 Plus Fingerprint Sensor Replacement, Releasing the Back Cover: step 2, image 3 of 3
    • Insert your pick in the top left-hand corner where the little indent is.
    • Slide the pick all the way around the phone until the back cover is loose and ready to be released.
  3. BLU R2 Plus Fingerprint Sensor Replacement, Remove Back Cover: step 3, image 1 of 1
    • Remove the Back Cover to gain access to sim card trays, the memory card slot, or just to replace it.
  4. BLU R2 Plus Fingerprint Sensor Replacement, Tape the sticker: step 4, image 1 of 3 BLU R2 Plus Fingerprint Sensor Replacement, Tape the sticker: step 4, image 2 of 3 BLU R2 Plus Fingerprint Sensor Replacement, Tape the sticker: step 4, image 3 of 3
    • Use a plastic opening pick to peel up the sticker from the arms of both the upper and lower plastic plates on both sides of the battery. This will reveal screws to both plates.
    • To hold back the sticker, use small bits of tape.
  5. BLU R2 Plus Fingerprint Sensor Replacement, Unscrew Upper Plastic Plate: step 5, image 1 of 1
    • Use a Phillips #00 screwdriver to unscrew the nine screws from the upper plastic plate.
  6. BLU R2 Plus Fingerprint Sensor Replacement, Upper Plate Removal: step 6, image 1 of 3 BLU R2 Plus Fingerprint Sensor Replacement, Upper Plate Removal: step 6, image 2 of 3 BLU R2 Plus Fingerprint Sensor Replacement, Upper Plate Removal: step 6, image 3 of 3
    • Using an opening pick to wedge under spaces around the upper plate, unclip the upper plate from the phone and slide it up and out.
  7. BLU R2 Plus Fingerprint Sensor Replacement, Fingerprint Sensor: step 7, image 1 of 3 BLU R2 Plus Fingerprint Sensor Replacement, Fingerprint Sensor: step 7, image 2 of 3 BLU R2 Plus Fingerprint Sensor Replacement, Fingerprint Sensor: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to carefully pull up the fingerprint sensor from the upper plate.
Derek Thomas
778 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 16
All Time: 158
