BLU Studio 5.0 S II Screen Replacement
  1. BLU Studio 5.0 S II Screen Replacement, Remove back cover: step 1, image 1 of 1
    • Remove the back cover of the phone with the plastic opening tool, or your fingers.
  2. BLU Studio 5.0 S II Screen Replacement, Remove battery: step 2, image 1 of 1
    • Remove the battery from the phone with the plastic opening tool, or your fingers.
  3. BLU Studio 5.0 S II Screen Replacement, Motherboard: step 3, image 1 of 2 BLU Studio 5.0 S II Screen Replacement, Motherboard: step 3, image 2 of 2
    • Remove the microSD and SIM card. Gently tug on the microSD and SIM card to slide them out of their insert.
  4. BLU Studio 5.0 S II Screen Replacement: step 4, image 1 of 2 BLU Studio 5.0 S II Screen Replacement: step 4, image 2 of 2
    • Locate the 5 black 3.5mm screws and the 1 3.5mm silver screw on the top back plate.
    • Remove the 6 3.5mm screws by using a Phillips #00 screwdriver.
  5. BLU Studio 5.0 S II Screen Replacement: step 5, image 1 of 2 BLU Studio 5.0 S II Screen Replacement: step 5, image 2 of 2
    • Remove the inner top back black plate.
  6. BLU Studio 5.0 S II Screen Replacement: step 6, image 1 of 2 BLU Studio 5.0 S II Screen Replacement: step 6, image 2 of 2
    • Locate the 2 black 3.5mm screws on the motherboard.
    • Remove the black 3.5 mm screws using a Phillips #00 screwdriver.
  7. BLU Studio 5.0 S II Screen Replacement: step 7, image 1 of 3 BLU Studio 5.0 S II Screen Replacement: step 7, image 2 of 3 BLU Studio 5.0 S II Screen Replacement: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Locate the 2 orange ribbons on opposite sides.
    • Carefully remove the two ribbon cables using tweezers.
    • Gently rock the cable back and forth equally from both sides to not damage the pins.
  8. BLU Studio 5.0 S II Screen Replacement: step 8, image 1 of 2 BLU Studio 5.0 S II Screen Replacement: step 8, image 2 of 2
    • Gently rock the plastic opening tool back and forth until the motherboard releases from the phone.
    • Adhesion, identified with red circles, bonds the motherboard to the chassis. This may require extra effort to lift off from back of phone.
  9. BLU Studio 5.0 S II Screen Replacement: step 9, image 1 of 2 BLU Studio 5.0 S II Screen Replacement: step 9, image 2 of 2
    • Follow the wire from the motherboard.
    • Remove the black lining covering the wire.
  10. BLU Studio 5.0 S II Screen Replacement: step 10, image 1 of 2 BLU Studio 5.0 S II Screen Replacement: step 10, image 2 of 2
    • Locate the 5 black screws on inner black lower plate.
  11. BLU Studio 5.0 S II Screen Replacement: step 11, image 1 of 2 BLU Studio 5.0 S II Screen Replacement: step 11, image 2 of 2
    • Remove the bottom inner back plate.
  12. BLU Studio 5.0 S II Screen Replacement: step 12, image 1 of 2 BLU Studio 5.0 S II Screen Replacement: step 12, image 2 of 2
    • Holding the cable with the removal tool, gently pull in the direction of the cable to remove the connector from its socket.
  13. BLU Studio 5.0 S II Screen Replacement: step 13, image 1 of 1
    • Remove the whole motherboard.
    • The Motherboard contains the headphone jack and the power button.
  14. BLU Studio 5.0 S II Screen Replacement, Screen: step 14, image 1 of 2 BLU Studio 5.0 S II Screen Replacement, Screen: step 14, image 2 of 2
    • Peel off the bottom back with finger or supdger.
    • CAUTION: Adhesive is attached to the bottom circuitboard. May require extra effort to remove.
To reassemble your device, follow these instructions in reverse order with the screen replacement.
2 other people completed this guide.
Curt Collingwood
261 Reputation
2 Guides authored
IUPUI, Team S2-G3, Harley Spring 2017 Member of IUPUI, Team S2-G3, Harley Spring 2017
IUPUI-HARLEY-S17S2G3
4 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 790
