BLU Tank II Keypad Replacement
  1. BLU Tank II Keypad Replacement, Back Panel: step 1, image 1 of 2 BLU Tank II Keypad Replacement, Back Panel: step 1, image 2 of 2
    • With the screen facing you, find the left corner of the phone. There should be a visible groove.
    • With your fingers, carefully press a fingernail into the slot and separate the back panel from the phone.
  2. BLU Tank II Keypad Replacement, Battery: step 2, image 1 of 1
    • After the back panel has been removed, put your finger on and press down on the bottom part of the battery.
    • Lift the battery up and carefully remove the battery.
  3. BLU Tank II Keypad Replacement, Front Panel: step 3, image 1 of 2 BLU Tank II Keypad Replacement, Front Panel: step 3, image 2 of 2
    • Using the phillips head screwdriver, remove all 5 2.5mm screws.
  4. BLU Tank II Keypad Replacement: step 4, image 1 of 1
    • Wedge the blue plastic iFixit opening tool between the front plate and the outer lens plate.
    • Carefully separate the front plate from all sides of the phone.
  5. BLU Tank II Keypad Replacement, Keypad: step 5, image 1 of 3 BLU Tank II Keypad Replacement, Keypad: step 5, image 2 of 3 BLU Tank II Keypad Replacement, Keypad: step 5, image 3 of 3
    • Once the front plate is separated from the outer lens plate, place your fingers on the backside of the keypad.
    • Peel the keypad out from the keyholes in the front plate.
David Kelchner
632 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 236
