BMX Chain Sprocket Replacement
  1. BMX Chain Sprocket Replacement, BMX Chain Sprocket: step 1, image 1 of 2 BMX Chain Sprocket Replacement, BMX Chain Sprocket: step 1, image 2 of 2
    • Flip the bike upside down in a position where the back wheel can spin freely.
    • Gather your tools.
  2. BMX Chain Sprocket Replacement: step 2, image 1 of 2 BMX Chain Sprocket Replacement: step 2, image 2 of 2
    • Get a ratchet, socket, extension and connect the extension to the socket and the ratchet to the extension.
    • Insert the socket with the extension in the peg till it hits the end.
    • Loosen the nut inside the peg.
    • Repeat these steps for the other side.
  3. BMX Chain Sprocket Replacement: step 3, image 1 of 2 BMX Chain Sprocket Replacement: step 3, image 2 of 2
    • Push the wheel forward till it stops, and there is no gap.
  4. BMX Chain Sprocket Replacement: step 4, image 1 of 2 BMX Chain Sprocket Replacement: step 4, image 2 of 2
    • Grab the chain
    • Slightly pull the chain to the side, away and back from the wheel
    • Make sure that it isn't attached to the wheel driver (spikes that chain sits on normally to make bike wheel move)
    • Make sure to keep an eye out for your fingers because you can get your hand caught between the chain and the wheel
  5. BMX Chain Sprocket Replacement: step 5, image 1 of 3 BMX Chain Sprocket Replacement: step 5, image 2 of 3 BMX Chain Sprocket Replacement: step 5, image 3 of 3
    • Grab the chain by the sprocket on the bottom of the bike
    • Pick it up and slightly pull to the side to remove the chain from the sprocket
    • Spin bike cranks to create clearance to move chain away from the sprocket and off the cranks
  6. BMX Chain Sprocket Replacement: step 6, image 1 of 2 BMX Chain Sprocket Replacement: step 6, image 2 of 2
    • Grab the Allen key that fits the compression bold
    • Loosen the compression bold
    • Completely remove the compression bold from the cranks
  7. BMX Chain Sprocket Replacement: step 7, image 1 of 2 BMX Chain Sprocket Replacement: step 7, image 2 of 2
    • Use the Allen key that fits the smaller bolt to loosen the cranks.
    • Loosen the bolt on the cranks.
    • Do not remove the bolt.
  8. BMX Chain Sprocket Replacement: step 8, image 1 of 3 BMX Chain Sprocket Replacement: step 8, image 2 of 3 BMX Chain Sprocket Replacement: step 8, image 3 of 3
    • Pull crank with the sprocket off the crank spindle.
    • Loosen the bolt that is holding sprocket (optional depending if cranks have the bolt).
    • Remove the sprocket from crank.
  9. BMX Chain Sprocket Replacement: step 9, image 1 of 3 BMX Chain Sprocket Replacement: step 9, image 2 of 3 BMX Chain Sprocket Replacement: step 9, image 3 of 3
    • Place the new sprocket on the cranks with the corresponding hole to hold the sprocket still.
    • Tighten the bolt to keep the sprocket in place (optional depending on bike cranks).
    • Push the cranks back onto the crank spindle still it stops moving and the other crank isn't pushed out.
    • Make sure that the crank is placed well and balanced.
  10. BMX Chain Sprocket Replacement: step 10, image 1 of 3 BMX Chain Sprocket Replacement: step 10, image 2 of 3 BMX Chain Sprocket Replacement: step 10, image 3 of 3
    • Thread in the crank compression bolt by hand on the cranks.
    • Use the Allen wrench to tighten the compression bolt and compress the crank and the crank spindle together.
  11. BMX Chain Sprocket Replacement: step 11, image 1 of 1
    • Use the Allen key to tighten the smaller compression bolt and prevent the cranks from spinning.
  12. BMX Chain Sprocket Replacement: step 12, image 1 of 3 BMX Chain Sprocket Replacement: step 12, image 2 of 3 BMX Chain Sprocket Replacement: step 12, image 3 of 3
    • Spin the crank with the sprocket to the position where the pedal is close to the peg.
    • Grab the chain.
    • Hover over the pedal to where you can place the chain back onto the sprocket.
    • Make sure that the chain is placed correctly on the sprocket.
    • Make sure to keep an eye out for your fingers because you can get your hand caught between the chain and the wheel.
  13. BMX Chain Sprocket Replacement: step 13, image 1 of 3 BMX Chain Sprocket Replacement: step 13, image 2 of 3 BMX Chain Sprocket Replacement: step 13, image 3 of 3
    • Place the chain back on the the wheel drive on the back wheel.
    • Spin the back wheel backwards so the chain can get rotation and sit correctly on the driver.
  14. BMX Chain Sprocket Replacement: step 14, image 1 of 2 BMX Chain Sprocket Replacement: step 14, image 2 of 2
    • Pull the back wheel till it stops moving.
    • Align the wheel so it wont hit either side of the frame.
  15. BMX Chain Sprocket Replacement: step 15, image 1 of 3 BMX Chain Sprocket Replacement: step 15, image 2 of 3 BMX Chain Sprocket Replacement: step 15, image 3 of 3
    • Use the socket with ratchet and the extension to tighten the nut inside the peg slightly, which will allow the wheel to move slightly if needed.
    • Do the same thing on the other side.
    • Once the wheel is aligned, tighten one side slightly and then tighten the other side slightly as well.
    • Keep doing this process until the nuts are tightened enough to they won't move without the use of the ratchet.
  16. BMX Chain Sprocket Replacement: step 16, image 1 of 1
    • Flip the bike right side up and the bike is ready to go.
The new bike sprocket will be installed if bike sprocket was broken or wanted a new one
Andy Barrientos
253 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 34
All Time: 484
