BMX Handlebars Replacement
  1. BMX Handlebars Replacement, BMX Handlebars: step 1, image 1 of 1
    • Locate the stem of the bike connecting the handlebars to the steerer tube of the fork.
  2. BMX Handlebars Replacement: step 2, image 1 of 2 BMX Handlebars Replacement: step 2, image 2 of 2
    • Remove the four bolts from the face of stem with a 6mm Allen key.
    • BMX bolts typically use a 6mm standard, but some equipment may differ.
  3. BMX Handlebars Replacement: step 3, image 1 of 1
    • Remove the faceplate of the stem.
  4. BMX Handlebars Replacement: step 4, image 1 of 1
    • Remove the old handlebars.
    • Place the new bars in the curved area of the stem where the old bars were located.
  5. BMX Handlebars Replacement: step 5, image 1 of 1
    • Place the faceplate of the stem back on and align the screw holes.
  6. BMX Handlebars Replacement: step 6, image 1 of 1
    • Insert the four screws back into the stem and tighten them half way with the 6mm Allen wrench.
  7. BMX Handlebars Replacement: step 7, image 1 of 2 BMX Handlebars Replacement: step 7, image 2 of 2
    • Align your handlebars so they are straight, balanced, and to your liking.
    • Tighten the bolts in an "X" pattern a half turn at a time.
  8. BMX Handlebars Replacement: step 8, image 1 of 1
    • Pull up on your handlebars and make sure they are tight enough that they do not move.
To reassemble your device, follow these instructions in order.
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 20
All Time: 719
