BOSE SoundTouch 30 Power Supply Replacement
Brennen Irey
Brennen Irey and 2 other contributors
Last updated on May 29, 2018
10 minutes
Moderate
Introduction
Go to step 1
This guide will show the steps needed to remove the power supply from the BOSE SoundTouch 30.
iFixit earns commission when you buy through these links.
  1. BOSE SoundTouch 30 Power Supply Replacement, Base Plate: step 1, image 1 of 2 BOSE SoundTouch 30 Power Supply Replacement, Base Plate: step 1, image 2 of 2
    • Remove the four 15.5 mm PH2 screws securing the base plate to the device.
  2. BOSE SoundTouch 30 Power Supply Replacement, Power Supply: step 2, image 1 of 1
    • Remove the six 15.5mm PH2 screws securing the grille and rear panel to the device.
  3. BOSE SoundTouch 30 Power Supply Replacement: step 3, image 1 of 2 BOSE SoundTouch 30 Power Supply Replacement: step 3, image 2 of 2
    • Remove the grille and rear panel by grabbing the corners and pulling upwards and outwards.
    • There is a small ribbon cable that connects the display assembly to the body of the device. Make sure to disconnect the cable before pulling the grille all the way off or else the cable could snap.
  4. BOSE SoundTouch 30 Power Supply Replacement: step 4, image 1 of 1
    • Remove all four 15.5 mm PH2 screws holding the power supply down.
    • The power supply is identified by a green board with a large metal covering.
  5. BOSE SoundTouch 30 Power Supply Replacement: step 5, image 1 of 2 BOSE SoundTouch 30 Power Supply Replacement: step 5, image 2 of 2
    • Disconnect the three cables from the power supply by squeezing the white tabs if present and gently pulling.
    • Pick up the power supply and remove the fourth cable from the underside of the power supply.
    • Remove the power supply.
11 other people completed this guide.
Brennen Irey
1,197 Reputation
6 Guides authored
Cal Poly, Team S16-G2, Livingston Spring 2018 Member of Cal Poly, Team S16-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G2
4 Members
7 Guides authored
30 Comments
where can we buy the [power supply unit, as i have messed mine by using 220v instead of 110v
Hitesh Gohill - Reply
Hello. Do you want to exchange power supplies?
Contact me please!
Tomás Rosales -
Hi. My name Josley from Brazil.
I need you Power supply module for bose soundtouch 30.
You can help me?
Josley Oliveira -
Hola donde puedo comprar el modulo SoundTouch 30 Power Supply.
Muchas gracias.
Isidro -
I have the opposite problem. Bought the 110v instead of the 220v and now I have to use a step down transformer. Wanna exchange power supplies?
tomas@familiarosales.cl
Tomás Rosales - Reply
Past 24 Hours: 6
Past 7 Days: 37
Past 30 Days: 97
All Time: 11,424
