BRCK v1 Battery Replacement
  1. BRCK v1 Battery Replacement, Antenna: step 1, image 1 of 1
    • Stand the device on its side so the antenna is sitting on the top.
  2. BRCK v1 Battery Replacement: step 2, image 1 of 2 BRCK v1 Battery Replacement: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • Use the tweezers to grip the neck of the antenna(the part closest to the device).
    • Use opposite hand to twist off the body of the antenna.
  3. BRCK v1 Battery Replacement, Top Cover: step 3, image 1 of 1
    • Place the face of the device showing BRCK face up.
  4. BRCK v1 Battery Replacement: step 4, image 1 of 1
    • Remove the four screws(4mm hex head) on the corners of the device with a Hex 2.0 Screwdriver.
  5. BRCK v1 Battery Replacement: step 5, image 1 of 1
    • Remove the top cover.
  6. BRCK v1 Battery Replacement, Motherboard: step 6, image 1 of 2 BRCK v1 Battery Replacement, Motherboard: step 6, image 2 of 2
    • Remove the nut and washer from the RF connector, located where the antenna was connected.
  7. BRCK v1 Battery Replacement: step 7, image 1 of 2 BRCK v1 Battery Replacement: step 7, image 2 of 2
    • Unplug the red, black, and yellow wire connection by lifting up.
  8. BRCK v1 Battery Replacement: step 8, image 1 of 3 BRCK v1 Battery Replacement: step 8, image 2 of 3 BRCK v1 Battery Replacement: step 8, image 3 of 3
    Buy
    • Carefully insert tweezers under the black tab, and lift to release the clip.
    • Slide the ribbon out from under the clip to free the motherboard.
  9. BRCK v1 Battery Replacement: step 9, image 1 of 1
    • Remove outside rubber covers by lifting them out of place.
  10. BRCK v1 Battery Replacement: step 10, image 1 of 3 BRCK v1 Battery Replacement: step 10, image 2 of 3 BRCK v1 Battery Replacement: step 10, image 3 of 3
    • Slowly lift the motherboard out from the device by lifting it from the end next to the ribbon connection.
    • Lift and pull out of place.
  11. BRCK v1 Battery Replacement, Battery: step 11, image 1 of 3 BRCK v1 Battery Replacement, Battery: step 11, image 2 of 3 BRCK v1 Battery Replacement, Battery: step 11, image 3 of 3
    • Flip device upside down. Hold the device and tap into your other hand with varying force to remove battery.
    • This may take a few tries to remove the battery.
Jeret Buerger
501 Reputation
5 Guides authored
Cal Poly, Team 12-3, Lancaster Spring 2015 Member of Cal Poly, Team 12-3, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G3
3 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 20
All Time: 342
