BRCK v1 Modem Replacement
  1. BRCK v1 Modem  Replacement, Top Cover: step 1, image 1 of 1
    • Place the face of the device showing BRCK face up.
  2. BRCK v1 Modem  Replacement: step 2, image 1 of 1
    • Remove the four screws(4mm hex head) on the corners of the device with a Hex 2.0 Screwdriver.
  3. BRCK v1 Modem  Replacement: step 3, image 1 of 1
    • Remove the top cover.
  4. BRCK v1 Modem  Replacement, Modem: step 4, image 1 of 1
    • Cut the black zip tie holding the modem down.
    • Caution By cutting the zip tie, you void any manufacturer warranty you may have on the device.
  5. BRCK v1 Modem  Replacement: step 5, image 1 of 1
    • Remove the connection located on the edge of the modem.
  6. BRCK v1 Modem  Replacement: step 6, image 1 of 2 BRCK v1 Modem  Replacement: step 6, image 2 of 2
    • Slightly lift the modem to reveal the brown ribbon connector and metal connection plate, located on the bottom of the modem.
  7. BRCK v1 Modem  Replacement: step 7, image 1 of 3 BRCK v1 Modem  Replacement: step 7, image 2 of 3 BRCK v1 Modem  Replacement: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Using your tweezers, gently push on the metal plate and slide it down toward the base of the modem to release the locking mechanism.
    • Lower the plate and gently pull the ribbon out of the face plate.
    • Caution Be extremely gentle while preforming this step. The ribbon is brittle and prone to breaking if bent too much. Make sure you go slowly so that you do not damage the device.
  8. BRCK v1 Modem  Replacement: step 8, image 1 of 2 BRCK v1 Modem  Replacement: step 8, image 2 of 2
    • Remove the modem from the device.
Jeret Buerger
501 Reputation
5 Guides authored
Cal Poly, Team 12-3, Lancaster Spring 2015 Member of Cal Poly, Team 12-3, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G3
3 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 364
