BT008 Fitness tracker disassembly
  1. BT008 Fitness tracker disassembly, View: step 1, image 1 of 2 BT008 Fitness tracker disassembly, View: step 1, image 2 of 2
    • The device itself.
  2. BT008 Fitness tracker disassembly, Remove strap: step 2, image 1 of 3 BT008 Fitness tracker disassembly, Remove strap: step 2, image 2 of 3 BT008 Fitness tracker disassembly, Remove strap: step 2, image 3 of 3
    • Removing soft strap.
    • The device is pretty smart. It turns off those green puls measuring LED`s so it`s tricky to take a picture of those glowing.
  3. BT008 Fitness tracker disassembly, Removing back cover: step 3, image 1 of 3 BT008 Fitness tracker disassembly, Removing back cover: step 3, image 2 of 3 BT008 Fitness tracker disassembly, Removing back cover: step 3, image 3 of 3
    • Remove 4 screws in corners from the back. Remove the cover. Thin silicone washer is visible now. The buttons look waterproof.
  4. BT008 Fitness tracker disassembly, Removing the motherboard: step 4, image 1 of 3 BT008 Fitness tracker disassembly, Removing the motherboard: step 4, image 2 of 3 BT008 Fitness tracker disassembly, Removing the motherboard: step 4, image 3 of 3
    • Remove one more screw. Now 100mAh is visible. Also we can see some modules under the LCD panel. Will get there later.
    • SURPRISE! the MCU is barried under a blob of epoxy(
    • USB connector has only teo wires out for charging.
    • And a reset button. Definitely not waterproof. Same as USB port cap. Why putting so much effort on that buttons and seal if anything else is not protected?!
  5. BT008 Fitness tracker disassembly, Going deeper: step 5, image 1 of 3 BT008 Fitness tracker disassembly, Going deeper: step 5, image 2 of 3 BT008 Fitness tracker disassembly, Going deeper: step 5, image 3 of 3
    • Double sided tape holds the battery.
    • Separate plastic frame for LED`s is holded by two latches which are holded by a plastic flake. Rather complex.
  6. BT008 Fitness tracker disassembly, Almost there: step 6, image 1 of 3 BT008 Fitness tracker disassembly, Almost there: step 6, image 2 of 3 BT008 Fitness tracker disassembly, Almost there: step 6, image 3 of 3
    • With frame removed. The flexible PCB with LED`s is also mounted on a double sided tape. While removing try to rip this corner with much copper on it.
    • Those traces are signed, so cute.
    • Vibromotor is glued firmly.
  7. BT008 Fitness tracker disassembly, Removing LCD panel: step 7, image 1 of 3 BT008 Fitness tracker disassembly, Removing LCD panel: step 7, image 2 of 3 BT008 Fitness tracker disassembly, Removing LCD panel: step 7, image 3 of 3
    • Plastic frame is holded by two pins. Now remove 4 screws holding the panel.
    • Two modules under the panels. Bluetooth 4 on the left. Unknown module on the right.
    • Scoped photo of the right one.
    • LCD panel works fine after reassembling.
ASDF ASDF
11 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 476
