Baby Einstein Take Along Tunes Battery Socket Replacement
  1. Baby Einstein Take Along Tunes Battery Socket Replacement, Battery Socket: step 1, image 1 of 1
    • Set the device on it's face with the back facing up.
  2. Baby Einstein Take Along Tunes Battery Socket Replacement: step 2, image 1 of 1
    • Begin by removing all highlighted screws with a using a Phillips #1 Screwdriver.
  3. Baby Einstein Take Along Tunes Battery Socket Replacement: step 3, image 1 of 1
    • Remove the battery plate with a plastic opening tool and set it aside.
  4. Baby Einstein Take Along Tunes Battery Socket Replacement: step 4, image 1 of 1
    • Remove each battery with a plastic opening tool and set them aside.
  5. Baby Einstein Take Along Tunes Battery Socket Replacement: step 5, image 1 of 1
    • Separate the device in two parts by using the plastic opening tool.
  6. Baby Einstein Take Along Tunes Battery Socket Replacement: step 6, image 1 of 1
    • Remove the top piece and place it aside, keeping the bottom half with the mechanics.
  7. Baby Einstein Take Along Tunes Battery Socket Replacement: step 7, image 1 of 1
    • Remove the highlighted screws using a Phillips #1 Screwdriver.
  8. Baby Einstein Take Along Tunes Battery Socket Replacement: step 8, image 1 of 1
    • Use the plastic opening tool and carefully set the LED panel to the side, exposing the wires underneath.
  9. Baby Einstein Take Along Tunes Battery Socket Replacement: step 9, image 1 of 1
    Tool used on this step:
    Buy
    • With the precision tweezers, straighten the metal connectors to remove the terminals from the other side.
  10. Baby Einstein Take Along Tunes Battery Socket Replacement: step 10, image 1 of 2 Baby Einstein Take Along Tunes Battery Socket Replacement: step 10, image 2 of 2
    • Sever the red wire from the metal connector with the precision tweezers.
  11. Baby Einstein Take Along Tunes Battery Socket Replacement: step 11, image 1 of 2 Baby Einstein Take Along Tunes Battery Socket Replacement: step 11, image 2 of 2
    • Sever the black wire from the metal connector with the precision tweezers.
  12. Baby Einstein Take Along Tunes Battery Socket Replacement: step 12, image 1 of 2 Baby Einstein Take Along Tunes Battery Socket Replacement: step 12, image 2 of 2
    • Flip the device on its face and remove the battery terminals with a metal spudger.
Shreya Sunny
607 Reputation
6 Guides authored
USF Tampa, Team 2-2, Sullivan Fall 2015 Member of USF Tampa, Team 2-2, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G2
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 30
All Time: 618
