Back Cover Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Back Cover Removal, Prepare your device for disassembly: step 1, image 1 of 3 Back Cover Removal, Prepare your device for disassembly: step 1, image 2 of 3 Back Cover Removal, Prepare your device for disassembly: step 1, image 3 of 3
    • Let your device's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
    • Completely power off your device and unplug all cables.
    • Consider laying your device on a soft cloth to prevent scratching or damaging the screen during your repair.
  2. Back Cover Removal, Unfasten the back cover: step 2, image 1 of 2 Back Cover Removal, Unfasten the back cover: step 2, image 2 of 2
    Tool used on this step:
    FixMat
    $36.95
    Buy
    • Use a Phillips #0 screwdriver to remove the five 17.2 mm‑long screws securing the top edge and bottom corners of the back cover.
    • Use a Phillips #0 screwdriver to fully loosen the remaining captive screw at the center of the bottom edge. This should create a small gap between the back cover and chassis.
    • Don't try to remove this screw.
  3. Back Cover Removal, Insert an opening pick: step 3, image 1 of 3 Back Cover Removal, Insert an opening pick: step 3, image 2 of 3 Back Cover Removal, Insert an opening pick: step 3, image 3 of 3
    • Insert the flat edge of an opening pick between the bottom edge of the back cover and chassis, near the captive screw.
    • Angle the pick upward and push it under the back cover.
  4. Back Cover Removal, Release the back cover's clips: step 4, image 1 of 3 Back Cover Removal, Release the back cover's clips: step 4, image 2 of 3 Back Cover Removal, Release the back cover's clips: step 4, image 3 of 3
    • Plastic clips secure the perimeter of the back cover. You should feel and hear them release during this step.
    • Slide the opening pick along the bottom edge and around the corners of the back cover to release the clips securing it.
    • Keep the pick at an upward angle under the back cover to help release the clips.
  5. Back Cover Removal, Remove the back cover: step 5, image 1 of 3 Back Cover Removal, Remove the back cover: step 5, image 2 of 3 Back Cover Removal, Remove the back cover: step 5, image 3 of 3
    • Lift the bottom edge of the back cover off the chassis to release the remaining clips.
    • Remove the back cover.
    • During reassembly, lay the back cover onto your device and firmly push down around the perimeter to engage the clips.
Spencer Day
155,298 Reputation
1,033 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,788 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 95
