Back Cover Replacement
  1. Back Cover Replacement, Back Cover: step 1, image 1 of 1
    • Power off Zoomer Dino Boomer before disassembly.
    • Remove the eight 9.3mm Phillips #1 screws.
  2. Back Cover Replacement: step 2, image 1 of 2 Back Cover Replacement: step 2, image 2 of 2
    • Turn dinosaur over and hold upright.
    • Use the spudger to pry apart the back cover from the remainder of the Zoomer Dino Boomer.
    • Be gentle while removing the back cover. The back cover of the Zoomer Dino Boomer is still connected to the electronic system by a wire.
  3. Back Cover Replacement: step 3, image 1 of 3 Back Cover Replacement: step 3, image 2 of 3 Back Cover Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Disconnect the wire that connects the back cover of the dino to the main circuit board by carefully pulling on the orange wire connector with tweezers.
    • Remove back cover.
    • If you are having difficulty removing the connector from its socket, push in the small tabs on the side of the connector with the tweezers. This step may take some work.
    • Do not damage the wires or circuit board.
Desiree DesJardins
452 Reputation
2 Guides authored
USF Tampa, Team 16-1, Wollert Fall 2015 Member of USF Tampa, Team 16-1, Wollert Fall 2015
USFT-WOLLERT-F15S16G1
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 732
