Back Panel Replacement
  1. Back Panel Replacement, Back Panel: step 1, image 1 of 3 Back Panel Replacement, Back Panel: step 1, image 2 of 3 Back Panel Replacement, Back Panel: step 1, image 3 of 3
    • First, remove the 6 screws in the back panel and pull the back panel off.
    • Separate the halves of the controller. However, be careful when separating due to the little wires that could get mixed up.
  2. Back Panel Replacement: step 2, image 1 of 3 Back Panel Replacement: step 2, image 2 of 3 Back Panel Replacement: step 2, image 3 of 3
    • Next, remove the rumble motor by unscrewing the 2 screws connecting it.
  3. Back Panel Replacement: step 3, image 1 of 3 Back Panel Replacement: step 3, image 2 of 3 Back Panel Replacement: step 3, image 3 of 3
    • Finally remove the screws holding in the right and left triggers. It's easiest to hold the trigger together as shown in the third picture. Remove both the left and right trigger, and then you have successfully removed your back panel.
David Mistretta
101 Reputation
1 Guide authored
UMass Dartmouth, Team 3-5, Isaacson Fall 2016 Member of UMass Dartmouth, Team 3-5, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G5
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 332
