Back Panel
Back Panel
Meredith Shaffer
Meredith Shaffer and 2 other contributors
Last updated on January 4, 2018
2 minutes
Easy
Introduction
Go to step 1
In this guide it teaches how to remove the back panel of the laptop. You will need a screwdriver and a opening tool to complete this task.
Tools
Show more…
  1. Back Panel, Back Panel: step 1, image 1 of 1
    • Flip the laptop so that the back is facing upwards.
    • Locate the small screw on the back that holds the "L" shaped panel.
    • Using a 0 Phillip Screwdriver (4.0x4.7mm sized screw), unscrew the screw. It will not become detached from the panel but it will allow you to remove the back panel.
  2. Back Panel: step 2, image 1 of 3 Back Panel: step 2, image 2 of 3 Back Panel: step 2, image 3 of 3
    • Using a plastic opening tool, pry the back panel from the computer, going all the way around it.
    • This will take a good amount of force and you will hear clicking noises as you snap each of the connections out of place.
  3. Back Panel: step 3, image 1 of 1
    • Once the back panel is completely removed you will have access to the RAM and many other connections in the computer.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 612
