Introduction
Use this guide to replace the left bumper in your Backbone One.
Lift up the upper part of the controller.
Swing over the upper cover and place it on the controller case.
Use the tip of an opening pick to open the gray flap of the ZIF connector by pushing it upwards.
Use your fingers to disconnect the interconnect cable from its connector.
Use a Phillips screwdriver to remove the 5.9 mm-long screw which is securing the trigger.
