Barnes And Noble Nook HD Tablet Screen Replacement
  1. Barnes And Noble Nook HD Tablet Screen Replacement, Remove the front screen: step 1, image 1 of 3 Barnes And Noble Nook HD Tablet Screen Replacement, Remove the front screen: step 1, image 2 of 3 Barnes And Noble Nook HD Tablet Screen Replacement, Remove the front screen: step 1, image 3 of 3
    • wedge the plastic opening piece underneath the bottom left hand corner of the front frame. Pry the frame off of the Nook.
  2. Barnes And Noble Nook HD Tablet Screen Replacement, Remove the screws: step 2, image 1 of 2 Barnes And Noble Nook HD Tablet Screen Replacement, Remove the screws: step 2, image 2 of 2
    • Remove every visible screw tying the chassis to the bottom frame using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
  3. Barnes And Noble Nook HD Tablet Screen Replacement, Remove the chassis: step 3, image 1 of 1
  4. Barnes And Noble Nook HD Tablet Screen Replacement, Detach battery: step 4, image 1 of 1
    • detach the battery ribbon from the motherboard.
  5. Barnes And Noble Nook HD Tablet Screen Replacement, Flip the nook: step 5, image 1 of 1
    • flip center chassis so that the back of the screen is facing you, and the hole is positioned in the bottom right corner.
  6. Barnes And Noble Nook HD Tablet Screen Replacement, Detach the screen from chassis part 1: step 6, image 1 of 3 Barnes And Noble Nook HD Tablet Screen Replacement, Detach the screen from chassis part 1: step 6, image 2 of 3 Barnes And Noble Nook HD Tablet Screen Replacement, Detach the screen from chassis part 1: step 6, image 3 of 3
    • Remove copper tape above the antenna, 3 quarters of the way up the left side of the nook.
  7. Barnes And Noble Nook HD Tablet Screen Replacement, Detach the screen from chassis part 2: step 7, image 1 of 2 Barnes And Noble Nook HD Tablet Screen Replacement, Detach the screen from chassis part 2: step 7, image 2 of 2
    Tool used on this step:
    Buy
    • Locate thin orange strip on the top side of the motherboard. Apply tweezers to the black casing that locks it into the motherboard (plastic piece will completely come out).
  8. Barnes And Noble Nook HD Tablet Screen Replacement, Detach the screen from chassis part 3: step 8, image 1 of 2 Barnes And Noble Nook HD Tablet Screen Replacement, Detach the screen from chassis part 3: step 8, image 2 of 2
    • Locate the foam covered orange strip on the motherboard. Pull up (away from motherboard) so that it i no longer connected to the motherboard.
  9. Barnes And Noble Nook HD Tablet Screen Replacement, Take motherboard away from the screen: step 9, image 1 of 2 Barnes And Noble Nook HD Tablet Screen Replacement, Take motherboard away from the screen: step 9, image 2 of 2
    • Lift motherboard away from the screen. Pull frame off of the screen.
  10. Barnes And Noble Nook HD Tablet Screen Replacement, Place new screen: step 10, image 1 of 2 Barnes And Noble Nook HD Tablet Screen Replacement, Place new screen: step 10, image 2 of 2
    • Put the new screen back into place in the frame (the reverse of step 9). Place motherboard back into place on the back of the screen. And follow steps in reverse order to reassemble.
9 other people completed this guide.
Elijah Gonsalves
1,049 Reputation
3 Guides authored
UMass Dartmouth, Team 2-3, Duarte Fall 2014 Member of UMass Dartmouth, Team 2-3, Duarte Fall 2014
UMASSD-DUARTE-F14S2G3
5 Members
10 Guides authored
One Comment
como faço para comprar a tela touch do tablet nook ce0984
sou de Fortaleza-Ceara - Brasil
meu e-mail é moreiragenesio@yahoo.com.br
moreiragenesio - Reply
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 33
All Time: 14,405
