Base Cover
Base Cover
Kiyan Mullen
Kiyan Mullen and 4 other contributors
Last updated on January 8, 2018
2 minutes
Easy
Introduction
Go to step 1
This guide will show you how to remove the base cover of your Alienware 17 R4. Removing the base cover is necessary to access the device's interior.
Tools
Show more…
  1. Base Cover, Base Cover: step 1, image 1 of 1
    • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
    • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
    • The M2x3 screw (1.9 mm) does not come out completely.
  2. Base Cover: step 2, image 1 of 2 Base Cover: step 2, image 2 of 2
    • Pull the base cover up to remove it.
    • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
    • Removing the cover may require some force.
Kiyan Mullen
505 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 33
All Time: 3,692
