Base Replacement
  1. Base Replacement, Base: step 1, image 1 of 2 Base Replacement, Base: step 1, image 2 of 2
    • Remove the four Phillips #0 screws (9.4mm) located at the bottom of the phone on the back side of the base.
  2. Base Replacement: step 2, image 1 of 1
    • Use the spudger to separate the bottom from the top.
    • There are two clips, located top and bottom, that you have to compress with the spudger.
2 other people completed this guide.
Josh Showalter
442 Reputation
3 Guides authored
IUPUI, Team 1-4, Baechle Spring 2016 Member of IUPUI, Team 1-4, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G4
4 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 10
All Time: 611
