Basis Peak Screen Replacement
  1. Basis Peak Screen Replacement, Frame: step 1, image 1 of 1
    • Flip the watch over and orient it such that the buckle is away from you and the back panel is revealed.
    • Maintain this orientation to follow the guide.
  2. Basis Peak Screen Replacement: step 2, image 1 of 2 Basis Peak Screen Replacement: step 2, image 2 of 2
    • Remove the four base screws using a size 2 TORX screwdriver to separate the back plate from the frame.
  3. Basis Peak Screen Replacement: step 3, image 1 of 1
    • Disconnect the ribbon cable on the left side of the motherboard by using a spudger.
  4. Basis Peak Screen Replacement: step 4, image 1 of 1
    • Use a spudger and apply pressure to the white plastic wall to the right of the motherboard. Use this to lever the electronics out of the frame.
    • The clips have small lips that you can put the spudger under to get more leverage.
    • Using any of the metal to pry out the electronics may damage some of the wiring. It is crucial to only press on the plastic.
  5. Basis Peak Screen Replacement, Screen: step 5, image 1 of 1
    • Flip over the motherboard complex and gently remove the screen with your fingers.
Steph
101 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 354
