Battery Blocking
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Battery Blocking, Unfasten the bottom cable shield: step 1, image 1 of 2 Battery Blocking, Unfasten the bottom cable shield: step 1, image 2 of 2
    • Use a Phillips screwdriver to remove the three 1.2 mm screws securing the bottom cable shield to the logic board.
  2. Battery Blocking, Remove the bottom cable shield: step 2, image 1 of 3 Battery Blocking, Remove the bottom cable shield: step 2, image 2 of 3 Battery Blocking, Remove the bottom cable shield: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers or your fingers to remove the bottom cable shield.
  3. Battery Blocking, Disconnect the battery: step 3, image 1 of 2 Battery Blocking, Disconnect the battery: step 3, image 2 of 2
    • Use a Phillips screwdriver to remove the 1.8 mm screw securing the battery connector to the logic board.
  4. Battery Blocking, Battery connector information: step 4, image 1 of 3 Battery Blocking, Battery connector information: step 4, image 2 of 3 Battery Blocking, Battery connector information: step 4, image 3 of 3
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
  5. Battery Blocking, Create a battery blocker: step 5, image 1 of 3 Battery Blocking, Create a battery blocker: step 5, image 2 of 3 Battery Blocking, Create a battery blocker: step 5, image 3 of 3
    • Cut two 6 mm wide strips from a playing card or cardstock to use as a battery blocker.
    • The strips should be about 4 cm long so you can easily grip them.
  6. Battery Blocking, Insert the card strips: step 6, image 1 of 3 Battery Blocking, Insert the card strips: step 6, image 2 of 3 Battery Blocking, Insert the card strips: step 6, image 3 of 3
    • Insert the card strips on each side of the battery connector until they stop.
Chayton Ritter
25,313 Reputation
105 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
16,054 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 19
All Time: 220
