Battery Disconnect
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Battery Disconnect, Prepare your Macbook Air for disassembly: step 1, image 1 of 3 Battery Disconnect, Prepare your Macbook Air for disassembly: step 1, image 2 of 3 Battery Disconnect, Prepare your Macbook Air for disassembly: step 1, image 3 of 3
    • Allow your MacBook's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully power off your MacBook.
    • Close the display and lay your MacBook upside down. Keep your laptop closed until you've physically disconnected the battery.
  2. Battery Disconnect, Unfasten the lower case: step 2, image 1 of 2 Battery Disconnect, Unfasten the lower case: step 2, image 2 of 2
    Tool used on this step:
    FixMat
    $36.95
    Buy
    • Use a P5 pentalobe screwdriver to remove the four 6.4 mm‑long screws securing the lower case.
  3. Battery Disconnect, Insert an opening pick: step 3, image 1 of 3 Battery Disconnect, Insert an opening pick: step 3, image 2 of 3 Battery Disconnect, Insert an opening pick: step 3, image 3 of 3
    • Apply a suction handle to the center of the lower case's front edge.
    • Pull up on the suction handle to create a gap between the lower case and the frame.
    • Insert an opening pick into the gap.
  4. Battery Disconnect, Release the snapping clips: step 4, image 1 of 3 Battery Disconnect, Release the snapping clips: step 4, image 2 of 3 Battery Disconnect, Release the snapping clips: step 4, image 3 of 3
    • During the next two steps you'll feel and hear six snapping clips release. If a clip doesn't release, insert your opening pick farther and try again.
    • Slide the pick to the bottom right corner to release the first clip.
    • Slide the pick around the corner and up the right edge to release the next two clips.
  5. Battery Disconnect: step 5, image 1 of 3 Battery Disconnect: step 5, image 2 of 3 Battery Disconnect: step 5, image 3 of 3
    • Insert the opening pick in the original gap created with the suction handle.
    • Slide the opening pick to the bottom left corner and up the left edge to release the three remaining snapping clips.
  6. Battery Disconnect, Release the sliding tabs: step 6, image 1 of 3 Battery Disconnect, Release the sliding tabs: step 6, image 2 of 3 Battery Disconnect, Release the sliding tabs: step 6, image 3 of 3
    • Four sliding tabs along the back edge of the MacBook firmly secure the lower case. Separating these tabs requires a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Keep the lower case flat to the frame and firmly slide it straight away from the back edge, one corner at a time, to disengage the sliding tabs.
    • Don't pull up until the cover is completely separated.
  7. Battery Disconnect, Remove the lower case: step 7, image 1 of 3 Battery Disconnect, Remove the lower case: step 7, image 2 of 3 Battery Disconnect, Remove the lower case: step 7, image 3 of 3
    • Remove the lower case.
    • During reassembly:
    • Set the lower case in place and align the sliding tabs with the screw heads they slide over. Press down and slide the lower case toward the back edge to engage the tabs—it'll stop sliding as the tabs engage.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push, there should be no gap along the back edge.
    • Once the lower case is flush with the frame, press down firmly along the perimeter to engage the six snapping clips.
    • You'll hear and feel a distinct click as each clip snaps into place.
  8. Battery Disconnect, Remove the battery connector cover tape: step 8, image 1 of 3 Battery Disconnect, Remove the battery connector cover tape: step 8, image 2 of 3 Battery Disconnect, Remove the battery connector cover tape: step 8, image 3 of 3
    Buy
    • Use blunt nose tweezers or your fingers to remove the piece of tape covering the battery connector cover.
    • During reassembly, use the leftover adhesive to secure the tape to the cover.
  9. Battery Disconnect, Remove the battery connector cover: step 9, image 1 of 3 Battery Disconnect, Remove the battery connector cover: step 9, image 2 of 3 Battery Disconnect, Remove the battery connector cover: step 9, image 3 of 3
    • Use a 3IP Torx Plus screwdriver to remove the two 1.5 mm‑long screws securing the battery connector cover.
    • Remove the cover.
  10. Battery Disconnect, Disconnect the battery: step 10, image 1 of 2 Battery Disconnect, Disconnect the battery: step 10, image 2 of 2
    • Use an opening pick to pry up and disconnect the battery connector.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It might take a few tries to align the connector.
Spencer Day
159,414 Reputation
1,043 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,927 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 88
