Battery Disconnect
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Battery Disconnect, Safety precautions: step 1, image 1 of 2 Battery Disconnect, Safety precautions: step 1, image 2 of 2
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power down your phone.
  2. Battery Disconnect, Adhesive information: step 2, image 1 of 3 Battery Disconnect, Adhesive information: step 2, image 2 of 3 Battery Disconnect, Adhesive information: step 2, image 3 of 3
    • Adhesive secures the perimeter of the rear cover to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the rear cover to avoid damaging the internal components.
    • Measure 3 mm from the tip and mark your opening pick with a permanent marker. Alternatively, you can tape a coin to a pick 3 mm from the tip.
  3. Battery Disconnect, Apply a suction handle: step 3, image 1 of 2 Battery Disconnect, Apply a suction handle: step 3, image 2 of 2
    • Attach a suction handle to the bottom edge of the rear cover, as close to the edge as possible.
  4. Battery Disconnect, Insert an opening pick: step 4, image 1 of 3 Battery Disconnect, Insert an opening pick: step 4, image 2 of 3 Battery Disconnect, Insert an opening pick: step 4, image 3 of 3
    • Pull up on the suction handle with strong, steady force to create a small gap under the rear cover.
    • Insert the tip of an opening pick in the gap.
  5. Battery Disconnect, Separate the rear cover adhesive: step 5, image 1 of 3 Battery Disconnect, Separate the rear cover adhesive: step 5, image 2 of 3 Battery Disconnect, Separate the rear cover adhesive: step 5, image 3 of 3
    • Slide your opening pick along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
  6. Battery Disconnect: step 6, image 1 of 3 Battery Disconnect: step 6, image 2 of 3 Battery Disconnect: step 6, image 3 of 3
    • Slide your opening pick up the left edge and along the top edge to separate the adhesive.
  7. Battery Disconnect: step 7, image 1 of 3 Battery Disconnect: step 7, image 2 of 3 Battery Disconnect: step 7, image 3 of 3
    • Slide your pick down the right edge to separate the remaining adhesive.
  8. Battery Disconnect, Prop up the rear cover: step 8, image 1 of 3 Battery Disconnect, Prop up the rear cover: step 8, image 2 of 3 Battery Disconnect, Prop up the rear cover: step 8, image 3 of 3
    • Don't try to fully remove the rear cover yet, as a ribbon cable on the right edge connects it to the phone.
    • Use the suction handle to lift the left edge of the rear cover and swing it over the right edge, like opening the cover of a book.
    • If you're having trouble, check the perimeter for any remaining adhesive and use your opening pick to separate it.
    • Prop up the rear cover with the suction handle so you can access the ribbon cable near the top right corner.
  9. Battery Disconnect, Remove the cable cover: step 9, image 1 of 2 Battery Disconnect, Remove the cable cover: step 9, image 2 of 2
    • Use a Torx Plus 3IP screwdriver to remove the two 5.2 mm‑long screws securing the cable cover.
  10. Battery Disconnect: step 10, image 1 of 2 Battery Disconnect: step 10, image 2 of 2
    • Use tweezers or your fingers to remove the cable cover.
  11. Battery Disconnect, Disconnect the rear cover: step 11, image 1 of 3 Battery Disconnect, Disconnect the rear cover: step 11, image 2 of 3 Battery Disconnect, Disconnect the rear cover: step 11, image 3 of 3
    • Use the point of a spudger to pry up and disconnect the rear cover press connector.
  12. Battery Disconnect, Remove the rear cover: step 12, image 1 of 1
    • Remove the rear cover.
    • During reassembly, follow this guide to apply new adhesive and install your back cover.
  13. Battery Disconnect, Peel up the cable cover tape: step 13, image 1 of 3 Battery Disconnect, Peel up the cable cover tape: step 13, image 2 of 3 Battery Disconnect, Peel up the cable cover tape: step 13, image 3 of 3
    • Use the tip of a spudger and your fingers to peel up the piece of tape near the left edge of your phone, enough that you can access the bracket and screws underneath.
    • You can completely remove the tape if you want, but be sure to keep it for reassembly.
  14. Battery Disconnect, Remove the cable cover: step 14, image 1 of 2 Battery Disconnect, Remove the cable cover: step 14, image 2 of 2
    • Use a Torx Plus 3IP screwdriver to remove the two 5.2 mm‑long screws securing the wireless charging cable cover.
  15. Battery Disconnect: step 15, image 1 of 2 Battery Disconnect: step 15, image 2 of 2
    • Use tweezers or your fingers to remove the cover.
  16. Battery Disconnect, Disconnect the wireless charging assembly: step 16, image 1 of 2 Battery Disconnect, Disconnect the wireless charging assembly: step 16, image 2 of 2
    • Use the tip of an opening pick to pry up and disconnect the wireless charging press‑connector.
  17. Battery Disconnect: step 17, image 1 of 3 Battery Disconnect: step 17, image 2 of 3 Battery Disconnect: step 17, image 3 of 3
    • Use the point of a spudger to pry up and disconnect the ultra‑wideband press connector.
  18. Battery Disconnect, Remove the wireless charging assembly screws: step 18, image 1 of 2 Battery Disconnect, Remove the wireless charging assembly screws: step 18, image 2 of 2
    • Use a Torx Plus 3IP screwdriver to remove the two 2.2 mm‑long screw securing the wireless charging assembly.
  19. Battery Disconnect, Remove the wireless charging assembly: step 19, image 1 of 2 Battery Disconnect, Remove the wireless charging assembly: step 19, image 2 of 2
    • Remove the wireless charging assembly.
  20. Battery Disconnect, Disconnect the battery: step 20, image 1 of 3 Battery Disconnect, Disconnect the battery: step 20, image 2 of 3 Battery Disconnect, Disconnect the battery: step 20, image 3 of 3
    • Use a spudger to pry up and disconnect the battery press connector.
Finish Line
Spencer Day
155,036 Reputation
1,033 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,781 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 49
