Battery Disconnect
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Battery Disconnect, Safety precautions: step 1, image 1 of 2 Battery Disconnect, Safety precautions: step 1, image 2 of 2
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power down your phone.
  2. Battery Disconnect, Adhesive information: step 2, image 1 of 3 Battery Disconnect, Adhesive information: step 2, image 2 of 3 Battery Disconnect, Adhesive information: step 2, image 3 of 3
    • Adhesive secures the perimeter of the rear cover to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the rear cover to avoid damaging the internal components.
    • Measure 3 mm from the tip and mark your opening pick with a permanent marker. Alternatively, you can tape a coin to a pick 3 mm from the tip.
  3. Battery Disconnect, Apply a suction handle: step 3, image 1 of 2 Battery Disconnect, Apply a suction handle: step 3, image 2 of 2
    • Attach a suction handle to the bottom edge of the rear cover, as close to the edge as possible.
  4. Battery Disconnect, Insert an opening pick: step 4, image 1 of 3 Battery Disconnect, Insert an opening pick: step 4, image 2 of 3 Battery Disconnect, Insert an opening pick: step 4, image 3 of 3
    • Pull up on the suction handle with strong, steady force to create a small gap under the rear cover.
    • Insert the tip of an opening pick in the gap.
  5. Battery Disconnect, Separate the rear cover adhesive: step 5, image 1 of 3 Battery Disconnect, Separate the rear cover adhesive: step 5, image 2 of 3 Battery Disconnect, Separate the rear cover adhesive: step 5, image 3 of 3
    • Slide your opening pick along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
  6. Battery Disconnect: step 6, image 1 of 3 Battery Disconnect: step 6, image 2 of 3 Battery Disconnect: step 6, image 3 of 3
    • Slide your opening pick up the left edge and along the top edge to separate the adhesive.
  7. Battery Disconnect: step 7, image 1 of 3 Battery Disconnect: step 7, image 2 of 3 Battery Disconnect: step 7, image 3 of 3
    • Slide your pick down the right edge to separate the remaining adhesive.
  8. Battery Disconnect, Prop up the rear cover: step 8, image 1 of 3 Battery Disconnect, Prop up the rear cover: step 8, image 2 of 3 Battery Disconnect, Prop up the rear cover: step 8, image 3 of 3
    • Don't try to fully remove the rear cover yet, as a ribbon cable on the right edge connects it to the phone.
    • Use the suction handle to lift the left edge of the rear cover and swing it over the right edge, like opening the cover of a book.
    • If you're having trouble, check the perimeter for any remaining adhesive and use your opening pick to separate it.
    • Prop up the rear cover with the suction handle so you can access the ribbon cable near the top right corner.
  9. Battery Disconnect, Remove the wireless charging assembly: step 9, image 1 of 2 Battery Disconnect, Remove the wireless charging assembly: step 9, image 2 of 2
    Tool used on this step:
    FixMat
    $36.95
    Buy
    • While the Pixel 9 Pro uses Torx Plus screws, standard Torx bits will also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP screwdriver to remove the five screws securing the wireless charging assembly:
    • Four 5.4 mm‑long screws
    • One 1.5 mm‑long screw
    • This screw is non‑magnetic—you may need to use tweezers to remove it.
  10. Battery Disconnect: step 10, image 1 of 3 Battery Disconnect: step 10, image 2 of 3 Battery Disconnect: step 10, image 3 of 3
    • Be very careful not to damage the spring contacts under the top left edge of the wireless charging assembly.
    • Use tweezers or your fingers to remove the wireless charging assembly.
  11. Battery Disconnect, Disconnect the rear cover: step 11, image 1 of 3 Battery Disconnect, Disconnect the rear cover: step 11, image 2 of 3 Battery Disconnect, Disconnect the rear cover: step 11, image 3 of 3
    • Insert the tip of an opening pick under the left edge of the rear cover press connector and pry straight up to disconnect it.
  12. Battery Disconnect, Remove the rear cover: step 12, image 1 of 1
    • Remove the rear cover.
    • During reassembly, follow this guide to apply new adhesive and install your rear cover.
  13. Battery Disconnect, Remove the cable cover: step 13, image 1 of 2 Battery Disconnect, Remove the cable cover: step 13, image 2 of 2
    • Use a Torx Plus 3IP screwdriver to remove the two screws securing the cable cover:
    • One 2.3 mm‑long screw
    • One 5.4 mm‑long screw
  14. Battery Disconnect: step 14, image 1 of 2 Battery Disconnect: step 14, image 2 of 2
    • Use tweezers or your fingers to remove the cable cover.
  15. Battery Disconnect, Disconnect the battery: step 15, image 1 of 3 Battery Disconnect, Disconnect the battery: step 15, image 2 of 3 Battery Disconnect, Disconnect the battery: step 15, image 3 of 3
    • Insert the point of a spudger under the right edge of the battery press connector and pry straight up to disconnect it.
Finish Line
Spencer Day
155,090 Reputation
1,033 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,781 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 57
