Battery Disconnection
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Battery Disconnection, Back Cover: step 1, image 1 of 2 Battery Disconnection, Back Cover: step 1, image 2 of 2
    • Remove the eight 4 mm T5 Torx screws from the bottom cover.
  2. Battery Disconnection: step 2, image 1 of 2 Battery Disconnection: step 2, image 2 of 2
    • Use a plastic opening tool to pry open the 'XPS' flap in the middle.
  3. Battery Disconnection: step 3, image 1 of 1
    • Remove the single Phillips screw hidden beneath the flap.
  4. Battery Disconnection: step 4, image 1 of 1
    • Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
  5. Battery Disconnection: step 5, image 1 of 1
    • Remove the bottom cover.
  6. Battery Disconnection, Battery Disconnection: step 6, image 1 of 2 Battery Disconnection, Battery Disconnection: step 6, image 2 of 2
    • Pull the battery cable connector towards the battery to disconnect it from its socket.
    • If the connector is stubborn, push a little at one side, then the other, to "walk" it out of its socket.
    • If you have trouble walking the connector out of the socket, use the point of a spudger to gently push on the connector indent to slide the connector out.
    • Do not pull up.
    • Open the display and press the power button for five seconds to drain any remaining charge from the system.
Jeff Suovanen
447,670 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,788 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 123
