Battery Replacement
  1. Battery Replacement, removal of bottom case: step 1, image 1 of 2 Battery Replacement, removal of bottom case: step 1, image 2 of 2
    • remove the feet with a spudger
  2. Battery Replacement: step 2, image 1 of 2 Battery Replacement: step 2, image 2 of 2
    • Remove the 11 screw with a PH0 screwdriver.
    • The screws are identical
  3. Battery Replacement: step 3, image 1 of 2 Battery Replacement: step 3, image 2 of 2
    • Insert a spudger between the bottom cover and the keyboard module, then go around the whole cover to uncip everything.
    • Remove the bottom cover from the computer.
  4. Battery Replacement: step 4, image 1 of 1
    • You now have acces to the inside of the machine.
  5. Battery Replacement, Battery: step 5, image 1 of 1
    • Remove the 3 screws that keep the battery in place, using a Phillips screwdriver.
  6. Battery Replacement: step 6, image 1 of 1
    • Disconnect the battery by gently lifting it.
    • Don't lift the battery too forcefully! It is held together by notches on the opposite side of the connector.
    • Pull the battery toward the top of the computer to dislodge it.
To put your device back together, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Léo FRAYSSE
1,379 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 37
All Time: 273
